[Ovmsdev] GPS / NMEA integration
Sun Dec 10 07:59:18 HKT 2017
Anything looking wrong here?
Am 10.12.2017 um 00:55 schrieb Michael Balzer:
> Nonsense, we're using pin 79, forget that…
> …still, it's shorted to GND on my module.
> Am 10.12.2017 um 00:53 schrieb Michael Balzer:
>> My multimeter says pin 79 (GNSS_ANT) is connected to GND (pins 77, 78 + 80 + frame etc.)…?
>> I've measured before & after unplugging the pigtail…
>> …and I think I found the bug: it seems our SIMCOM board design is wrong.
>> The official docs say GNSS_ANT is pin 79:
>> But we're using pin 78:
>> Mark, can you confirm this?
>> Am 09.12.2017 um 23:46 schrieb Michael Balzer:
>>> I'm currently working on the NMEA module. The MUX channel is working, but I don't get a GPS fix.
>>> I've tried all GPS commands and now suspect my SIMCOM module having a hardware issue.
>>> I'm doing this:
>>> OVMS > level debug
>>> OVMS > power simcom on
>>> …wait for the MUX to be ready, then issue…
>>> OVMS > simcom muxtx 4 AT+CGPSNMEA=1
>>> OVMS > simcom muxtx 4 AT+CGPS=1,1
>>> …now the SIMCOM begins sending NMEA $GPGGA lines once per second looking like this:
>>> D (2937174) SIMCOM rx: f9 05 ff 35 24 47 50 47 47 41 2c 2c 2c 2c 2c 2c ...5*$GPGGA,,,,,,*
>>> D (2937174) SIMCOM rx: 30 2c 2c 2c 2c 2c 2c 2c 2c 2a 36 36 0d 0a 60 f9 *0,,,,,,,,*66*..`.
>>> Normally the modem should get a GPS fix within about 1-2 minutes and begin filling data in the $GPGGA record.
>>> But my modem won't, it just keeps sending empty fields.
>>> Can someone please try this with his/her module?
>>> To disable the GPS receiver, issue:
>>> OVMS > simcom muxtx 4 AT+CGPS=0
>>> Thanks & regards,
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20171210/07eceb43/attachment.htm>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20171210/07eceb43/attachment-0006.png>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20171210/07eceb43/attachment-0007.png>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20171210/07eceb43/attachment-0008.png>
