Geir Øyvind Vælidalo
geir at validalo.net
Sun Dec 31 08:00:46 HKT 2017
I did a test where I created three counters.
One went into MCP2515_isr and counts every interrupt.
One was added as the first code line in mcp2515::RxCallback.
And the third one was added to RxCallBack, but right before we read the CAN frame via SPI that will end up in IncomingFrame. I.e. should be a count of every CAN frame.
This is what I got:
OVMS > can can2 status
CAN: can2
Mode: Active
Speed: 100000
Rx pkt: 82
MCP2515_isr: 239
RxCallback1: 320
RxCallback2: 295
Rx err: 0
Tx pkt: 0
Tx err: 0
Err flags: 0x2040
These numbers puzzles me. Shouldn’t RxCallback1 and RxCallback2 be less or equal to MCP2515_isr? Where does these extra 81 calls come from? I’m missing something here...
Also, RxCallback2 is much bigger than Rx pkt, which means not all frames are sent to IncomingFrame. I Believe the reason is this code in can.cpp CAN_rxtask:
case CAN_rxcallback:
while (msg.body.bus->RxCallback(&msg.body.frame))
me->IncomingFrame(&msg.body.frame);
break;
Is this correct? Wouldn’t it skip calling IncomingFrame it there are only one interrupt?
I would think this is would be more appropriate:
bool keepOn=true;
do
keepOn = msg.body.bus->RxCallback(&msg.body.frame);
}while(keepOn);
break;
Do you agree?
But, the interrupts still stops :-( What does the 0x2040 means? And where do that number comes from?
Best regards,
Geir
> 30. des. 2017 kl. 21:24 skrev Michael Balzer <dexter at expeedo.de>:
> MCP2515 Arduino
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20171231/e109ad74/attachment.html>
