    Sun Dec 31 01:52:13 HKT 2017
That's RX buffer 0 overflow:
…and the new code should have reset it automatically -- the status output shows the last error state that occurred.
Maybe that's a timing issue?
Are you sure about the 100 kbit? I've found 125 kbit in a forum:
http://www.mykiasoulev.com/forum/viewtopic.php?t=135#p1772
Am 30.12.2017 um 18:45 schrieb Geir Øyvind Vælidalo:
> Looks correct now, but as you guessed, it still stops.
> What does error flag 0x40 mean? Is the CAN_IRQ_ARB_LOST?
> Geir
>> 30. des. 2017 kl. 18:38 skrev Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>>:
>> OK, I found & fixed the cause for the invalid frames.
>> Please pull & try again -- but I doubt it's the fix for the stopping.
>> Am 30.12.2017 um 18:33 schrieb Michael Balzer:
>>> Do you get valid messages with the previous version?
>>> Am 30.12.2017 um 18:30 schrieb Geir Øyvind Vælidalo:
>>>> Ok, this is what I get. As you can see, it is the same.
>>>> OVMS >can can2 start active 100000
>>>> Can bus can2 started in mode active at speed 100000Kbps
>>>> V (740558) can: rx can2 id 1fffff44 len 8: 43 02 00 00 00 00 ff ff | C.......
>>>> V (740618) can: rx can2 id 000 len 8: b6 78 00 00 00 00 00 00 | .x......
>>>> V (740618) can: rx can2 id 000 len 8: ff fc 0f 03 ff 00 00 00 | ........
>>>> V (740628) can: rx can2 id 000 len 8: ff ff ff ff ff ff 00 00 | ........
>>>> V (740638) can: rx can2 id 000 len 8: 54 00 ff 00 00 00 00 00 | T.......
>>>> V (740648) can: rx can2 id 1fffffbe len 8: 4d 02 00 00 00 00 ff ff | M.......
>>>> V (740678) can: rx can2 id 000 len 8: 00 00 00 00 00 00 00 00 | ........
>>>> V (740748) can: rx can2 id 1fffff44 len 8: 40 02 00 00 00 00 ff ff | @.......
>>>> V (740818) can: rx can2 id 000 len 8: b6 78 00 00 00 00 00 00 | .x......
>>>> V (740818) can: rx can2 id 000 len 8: ff fc 0f 03 ff 00 00 00 | ........
>>>> V (740828) can: rx can2 id 000 len 8: ff ff ff ff ff ff 00 00 | ........
>>>> V (740838) can: rx can2 id 1fffff13 len 8: 43 02 00 00 00 00 ff ff | C.......
>>>> V (740848) can: rx can2 id 000 len 8: 54 00 ff 00 00 00 00 00 | T.......
>>>> V (740878) can: rx can2 id 000 len 8: 00 00 00 00 00 00 00 00 | ........
>>>> V (741018) can: rx can2 id 000 len 8: b6 78 00 00 00 00 00 00 | .x......
>>>> V (741018) can: rx can2 id 000 len 8: ff fc 0f 03 ff 00 00 00 | ........
>>>> V (741028) can: rx can2 id 1fffff44 len 8: 40 02 00 00 00 00 ff ff | @.......
>>>> V (741038) can: rx can2 id 000 len 8: 54 00 ff 00 00 00 00 00 | T.......
>>>> V (741078) can: rx can2 id 000 len 8: 00 00 00 00 00 00 00 00 | ........
>>>> OVMS >
>>>>> 30. des. 2017 kl. 18:24 skrev Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>>:
>>>>> OK, and as your log output was from your vehicle module, please also do…
>>>>> level verbose
>>>>> can can2 trace on
>>>>> …before activating the bus.
>>>>> Thanks,
>>>>> Michael
>>>>> Am 30.12.2017 um 18:22 schrieb Geir Øyvind Vælidalo:
>>>>>> Can status gave this:
>>>>>> CAN:       can2
>>>>>> Mode:      Active
>>>>>> Speed:     100000
>>>>>> Rx pkt:                     104
>>>>>> Rx err:                       0
>>>>>> Tx pkt:                       0
>>>>>> Tx err:                       0
>>>>>> Err flags: 0x40
>>>>>>> 30. des. 2017 kl. 18:13 skrev Geir Øyvind Vælidalo <geir at validalo.net <mailto:geir at validalo.net>>:
>>>>>>> Fantastic! I’m in my car right now, so I’ll test it right now 🙂
>>>>>>> Geir
>>>>>>>> 30. des. 2017 kl. 17:59 skrev Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>>:
>>>>>>>> Geir,
>>>>>>>> I've had a look into the mcp2515 driver and found some possible causes for your issue. Main possible cause would be there was no check or clearing of
>>>>>>>> RX buffer overflows.
>>>>>>>> There also was a chance the driver would read invalid frames, as the RX interrupts got cleared before the buffer content was fetched.
>>>>>>>> I think I've solved those issues, and I also added retrieving the tx/rx error counts and flags, so "can status" can actually show you errors that occurred.
>>>>>>>> I've got no simple means to check if my changes work and if they are more stable, I don't have a cable for can2/3.
>>>>>>>> Can you please pull & test?
>>>>>>>> Regards,
>>>>>>>> Michael
>>>>>>>> Am 30.12.2017 um 10:19 schrieb Geir Øyvind Vælidalo:
>>>>>>>>> can can2 status gave me the same result. Once it stopped after receiving just 4 frames on Can2. During the few restarts I did this morning, 251 was
>>>>>>>>> the most I got before it stopped.
>>>>>>>>> Can1 recieved 50000 frames in no time and kept on going. It seems Can2 is the problem. Don’t know what happened yesterday when can1 stopped…
>>>>>>>>> Geir
>>>>>>>>>> 29. des. 2017 kl. 22:23 skrev Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>>:
>>>>>>>>>> Geir,
>>>>>>>>>> can you check the output of "can … status" before and after death? Do the rx/tx counters still grow after death?
>>>>>>>>>> Regards,
>>>>>>>>>> Michael
>>>>>>>>>> Am 29.12.2017 um 22:14 schrieb Geir Øyvind Vælidalo:
>>>>>>>>>>> I’m having problems with IncomingFrameCan when reading from two can buses from the Kia Soul. One of the can buses dies prematurely, and quite fast,
>>>>>>>>>>> with no visible errors. Most of the time it is Can2 that dies, however that is not always the case.
>>>>>>>>>>> I tried with an almost empty IncomingFrameCan2, containing just a counter to see how many times it is called, and it varied from 15 to  almost 200
>>>>>>>>>>> before it dies.
>>>>>>>>>>> This is the code:
>>>>>>>>>>> RegisterCanBus(1, CAN_MODE_ACTIVE, CAN_SPEED_500KBPS);
>>>>>>>>>>> RegisterCanBus(2, CAN_MODE_ACTIVE, CAN_SPEED_100KBPS);
>>>>>>>>>>> void OvmsVehicleKiaSoulEv::IncomingFrameCan2(CAN_frame_t* p_frame)
>>>>>>>>>>> uint8_t *d = p_frame->data.u8;
>>>>>>>>>>> m_counter->SetValue( m_counter->AsInt()+1 );
>>>>>>>>>>> IncomingFrameCan1 is quite verbose, but should not take too long time to process. But I have a lot of Polls on Can1:
>>>>>>>>>>> static const OvmsVehicle::poll_pid_t vehicle_kiasoulev_polls[] =
>>>>>>>>>>>     { 0x7e2, 0x7ea, VEHICLE_POLL_TYPE_OBDIIVEHICLE,  0x02, {  30,  30,  30 } }, // VIN
>>>>>>>>>>>     { 0x7e4, 0x7ec, VEHICLE_POLL_TYPE_OBDIIGROUP,  0x01, {  30,  10,  10 } }, // BMC Diagpage 01
>>>>>>>>>>>     { 0x7e4, 0x7ec, VEHICLE_POLL_TYPE_OBDIIGROUP,  0x02, {  30,  30,  10 } }, // BMC Diagpage 02
>>>>>>>>>>>     { 0x7e4, 0x7ec, VEHICLE_POLL_TYPE_OBDIIGROUP,  0x03, {  30,  30,  10 } }, // BMC Diagpage 03
>>>>>>>>>>>     { 0x7e4, 0x7ec, VEHICLE_POLL_TYPE_OBDIIGROUP,  0x04, {  30,  30,  10 } }, // BMC Diagpage 04
>>>>>>>>>>>     { 0x7e4, 0x7ec, VEHICLE_POLL_TYPE_OBDIIGROUP,  0x05, {  30,  30,  10 } },// BMC Diagpage 05
>>>>>>>>>>>     { 0x794, 0x79c, VEHICLE_POLL_TYPE_OBDIIGROUP,  0x02, {  30,  30,  10 } }, // OBC - On board charger
>>>>>>>>>>>     { 0x7e2, 0x7ea, VEHICLE_POLL_TYPE_OBDIIGROUP,  0x00, {  30,  10,  10 } }, // VMCU Shift-stick
>>>>>>>>>>>     { 0x7e2, 0x7ea, VEHICLE_POLL_TYPE_OBDIIGROUP,  0x02, {  30,  10,   0 } }, // VMCU Motor temp++
>>>>>>>>>>>     { 0x7df, 0x7de, VEHICLE_POLL_TYPE_OBDIIGROUP,  0x06, {  30,  10,   0 } }, // TMPS
>>>>>>>>>>>     { 0x7c5, 0x7cd, VEHICLE_POLL_TYPE_OBDIIGROUP,  0x01, {  30,  10,   0 } }, // LDC - Low voltage DC-DC
>>>>>>>>>>>     { 0, 0, 0, 0, { 0, 0, 0 } }
>>>>>>>>>>> The few times that Can2 is the one that lives on, I can’t see any metrics from Can1.
>>>>>>>>>>> Current source can be seen here: https://github.com/goev/Open-Vehicle-Monitoring-System-3 in case someone can take a look.
>>>>>>>>>>> Any pointers to where I can start looking, or tips to what I can try?
>>>>>>>>>>> Best regards,
>>>>>>>>>>> Geir
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> OvmsDev mailing list
>>>>>>>>>>> OvmsDev at lists.teslaclub.hk
>>>>>>>>>>> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
>>>>>>>>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>>>>>>>>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
>>>>>>>>>> OvmsDev at lists.teslaclub.hk <mailto:OvmsDev at lists.teslaclub.hk>
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20171230/274bc11f/attachment-0001.html>
Type: image/png
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20171230/274bc11f/attachment-0001.png>
