[Ovmsdev] Modem link-drop crash
Sun Dec 24 15:52:13 HKT 2017
Seems to work better for me now. Here is a real disconnection (from network side):
D (3088634) SIMCOM rx: 50 44 3a 20 44 49 53 43 4f 4e 4e 45 43 54 45 44 PD: DISCONNECTED
D (3088634) SIMCOM rx: 0d 0a d4 f9 f9 11 ff 2f 0d 0a 2b 50 50 50 44 3a ......./..+PPPD:
D (3088634) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=d4, LEN=29)
D (3088634) gsm-mux: ChanProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, LEN=26, IFP=3)
D (3088634) simcom: rx line ch=3 len=19 : +PPPD: DISCONNECTED
I (3088634) simcom: PPP Connection disconnected
D (3088634) SIMCOM rx: 20 44 49 53 43 4f 4e 4e 45 43 54 45 44 0d 0a d9 DISCONNECTED...
D (3088634) SIMCOM rx: f9 .
D (3088634) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=d9, LEN=29)
D (3088634) gsm-mux: ChanProcessFrame(CHAN=4, ADDR=11, CTRL=ff, LEN=26, IFP=3)
D (3088634) simcom: rx line ch=4 len=19 : +PPPD: DISCONNECTED
E (3088644) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2
I (3089474) simcom: Lost network connection (+PPP disconnect in NetMode)
I (3089474) simcom: State: Enter NetLoss state
D (3089474) SIMCOM tx: f9 0d ff 19 41 54 2b 43 47 41 54 54 3d 30 0d 0a ....AT+CGATT=0..
D (3089474) SIMCOM tx: 14 f9 ..
I (3089474) gsm-ppp: Shutting down (hard)...
I (3089474) ovms-server-v2: Network is down, so disconnect network connection
D (3090734) SIMCOM rx: f9 0d ff 0d 0d 0a 4f 4b 0d 0a 0f f9 ......OK....
D (3091614) SIMCOM rx: f9 09 ff 25 7e ff 7d 23 c0 21 7d 25 7d 29 7d 20 ...%~.}#.!}%})}
D (3091614) SIMCOM rx: 7d 24 ff 7d 21 7e fb f9 }$.}!~..
I (3094604) gsm-ppp: StatusCallBack: User Interrupt
I (3094604) gsm-ppp: PPP connection has been closed
D (3094624) SIMCOM rx: f9 09 ff 1d 0d 0a 4e 4f 20 43 41 52 52 49 45 52 ......NO CARRIER
D (3094624) SIMCOM rx: 0d 0a d1 f9 f9 0d ff 1d 0d 0a 4e 4f 20 43 41 52 ..........NO CAR
D (3094624) SIMCOM rx: 52 49 45 52 0d 0a 13 f9 f9 11 ff 1d 0d 0a 4e 4f RIER..........NO
D (3094624) SIMCOM rx: 20 43 41 52 52 49 45 52 0d 0a 1e f9 f9 09 ff 2f CARRIER......./
D (3094624) SIMCOM rx: 0d 0a 2b 50 50 50 44 3a 20 44 49 53 43 4f 4e 4e ..+PPPD: DISCONN
D (3094624) SIMCOM rx: 45 43 54 45 44 0d 0a 16 f9 f9 0d ff 2f 0d 0a 2b ECTED......./..+
D (3094624) SIMCOM rx: 50 50 50 44 3a 20 44 49 53 43 4f 4e 4e 45 43 54 PPPD: DISCONNECT
D (3094624) SIMCOM rx: 45 44 0d 0a d4 f9 f9 11 ff 2f 0d 0a 2b 50 50 50 ED......./..+PPP
D (3094624) SIMCOM rx: 44 3a 20 44 49 53 43 4f 4e 4e 45 43 54 45 44 0d D: DISCONNECTED.
D (3094624) SIMCOM rx: 0a d9 f9 ...
I (3098474) simcom: State timeout, transition to 5
I (3098474) simcom: State: Enter NetWait state
D (3098474) gsm-nmea: GPS disabled
I (3098644) ovms-server-v2: Status: Waiting for network connectivity
I (3102474) simcom: State: Enter NetStart state
It tried to reconnect a few times, failing each time. Then, after a couple of minutes, the connection succeeded.
> On 24 Dec 2017, at 2:53 PM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> I found this patch from Espressif:
> https://github.com/espressif/esp-idf/pull/1100/commits/6dd48547adbdaf89e43b680dc027e5aa786d9c0e <https://github.com/espressif/esp-idf/pull/1100/commits/6dd48547adbdaf89e43b680dc027e5aa786d9c0e>
> They had only applied it to ‘master’, and not the ‘2.1’ branch we use. It seems to resolve the problem.
> I also made some changes to the ovms_server_v2 to try to tear down the connection _before_ the ppp link goes down (but I now think these are unnecessary, although probably beneficial).
> Can you guys try updating both your ESP IDF (based on open vehicles 2.1 repo) and ovms v3 firmware. See if it is more reliable? I will leave mine running now, to see if there is any improvement for long-lived connections.
>> On 19 Dec 2017, at 5:14 AM, Greg D. <gregd2350 at gmail.com <mailto:gregd2350 at gmail.com>> wrote:
>> Hi folks,
>> I left my module running with the modem connected (WiFi client off) for
>> a couple of days. V2 server configured and connected, but the phone
>> client was not running. The module was sitting on my desk (not in a
>> car), powered from the high-power USB port on my laptop. It was
>> blinking happily last night when I went to bed, but dark this morning.
>> Apparently had crashed and rebooted during the night.
>> Here's the trace-back from the screen. Looks like a link drop was the
>> trigger, or perhaps the result of something else.
>> Hope this helps,
>> Greg
>> I (129194054) ovms-server-v2: Send MP-0
>> S47,K,0,0,stopped,standard,0,0,0,0,0,0,0,21,0,0,0,0,0.00,0,0,0,0,-1,0,0,0,0,0,0,0,0.00,0.00,0
>> I (129194064) ovms-server-v2: Send MP-0
>> D0,0,5,0,0,0,0,0,0,129191,0,0,0,0,0,0,0,0,0,0
>> I (129795064) ovms-server-v2: Send MP-0
>> I (129795074) ovms-server-v2: Send MP-0
>> D0,0,5,0,0,0,0,0,0,129792,0,0,0,0,0,0,0,0,0,0
>> I (130030624) simcom: CREG Network Registration: Searching
>> I (130031414) simcom: Lost network connection (NetworkRegistration in
>> NetMode)
>> I (130031414) simcom: State: Enter NetLosGuru Meditation Error of type
>> LoadProhibited occurred on core 0. Exception was unhandled.
>> Register
>> dump:
>> PC : 0x4018f959 PS : 0x00060830 A0 : 0x8018a5d8
>> A1 :
>> 0x3ffd80f0
>> 0x4018f959: ip4_route at
>> /home/greg/esp/esp-idf/components/lwip/core/ipv4/ip4.c:223 (discriminator 2)
>> A2 : 0x0000f01d A3 : 0x00000000 A4 : 0x00000000
>> A5 : 0xfffffffc
>> A6 : 0x3fff2c8c A7 : 0x00000014 A8 : 0x00000000
>> A9 : 0x00000001
>> A10 : 0x502b34ca A11 : 0x00000001 A12 : 0x3f42ea90
>> A13 : 0x3f42eaa4
>> A14 : 0x3ffda120 A15 : 0x00000000 SAR : 0x0000000b
>> EXCCAUSE: 0x0000001c
>> EXCVADDR: 0x0000f0d2 LBEG : 0x4000c2e0 LEND : 0x4000c2f6
>> LCOUNT : 0xffffffff
>> Backtrace: 0x4018f959:0x3ffd80f0 0x4018a5d5:0x3ffd8110
>> 0x4018d3eb:0x3ffd8150 0x4018d40d:0x3ffd8180 0x4018d4ae:0x3ffd81a0
>> 0x4018d90c:0x3ffd81c0 0x4018e46a:0x3ffd81e0 0x4018e4ab:0x3ffd8200
>> 0x40196261:0x3ffd8220 0x4019882d:0x3ffd8240 0x40198874:0x3ffd8260
>> 0x40199e9d:0x3ffd8280 0x40198764:0x3ffd82a0 0x4019a8f2:0x3ffd82c0
>> 0x4019a92e:0x3ffd82e0 0x40196f25:0x3ffd8300 0x40199e9d:0x3ffd8320
>> 0x40197e68:0x3ffd8340 0x40196149:0x3ffd8360 0x401b470c:0x3ffd8380
>> 0x401825ad:0x3ffd83a0
>> 0x4018a5d5: tcp_rst at
>> /home/greg/esp/esp-idf/components/lwip/core/tcp_out.c:1336 (discriminator 4)
>> 0x4018d3eb: tcp_abandon at
>> /home/greg/esp/esp-idf/components/lwip/core/tcp.c:1630
>> 0x4018d40d: tcp_abort at
>> 0x4018d4ae: tcp_netif_ipv4_addr_changed_pcblist at
>> 0x4018d90c: tcp_netif_ipv4_addr_changed at
>> /home/greg/esp/esp-idf/components/lwip/core/tcp.c:1947
>> 0x4018e46a: netif_set_ipaddr at
>> /home/greg/esp/esp-idf/components/lwip/core/netif.c:452
>> 0x4018e4ab: netif_set_addr at
>> /home/greg/esp/esp-idf/components/lwip/core/netif.c:330
>> 0x40196261: cifaddr at
>> /home/greg/esp/esp-idf/components/lwip/netif/ppp/ppp.c:704
>> 0x4019882d: ipcp_clear_addrs at
>> /home/greg/esp/esp-idf/components/lwip/netif/ppp/ipcp.c:2192
>> 0x40198874: ipcp_down at
>> /home/greg/esp/esp-idf/components/lwip/netif/ppp/ipcp.c:2156
>> 0x40199e9d: fsm_lowerdown at
>> /home/greg/esp/esp-idf/components/lwip/netif/ppp/fsm.c:146
>> 0x40198764: ipcp_lowerdown at
>> /home/greg/esp/esp-idf/components/lwip/netif/ppp/ipcp.c:687
>> 0x4019a8f2: upper_layers_down at
>> /home/greg/esp/esp-idf/components/lwip/netif/ppp/auth.c:715
>> 0x4019a92e: link_down at
>> /home/greg/esp/esp-idf/components/lwip/netif/ppp/auth.c:701
>> 0x40196f25: lcp_down at
>> /home/greg/esp/esp-idf/components/lwip/netif/ppp/lcp.c:2341
>> 0x40197e68: lcp_lowerdown at
>> /home/greg/esp/esp-idf/components/lwip/netif/ppp/lcp.c:485
>> 0x40196149: ppp_close at
>> 0x401b470c: pppapi_do_ppp_close at
>> /home/greg/esp/esp-idf/components/lwip/api/pppapi.c:355
>> 0x401825ad: tcpip_thread at
>> /home/greg/esp/esp-idf/components/lwip/api/tcpip.c:474
>> Rebooting...
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20171224/76cd69b6/attachment-0001.html>
