[Ovmsdev] Modem LED control?
Thu Dec 21 11:25:54 HKT 2017
I think that this can control it (on SIM5360):
Disable:
simcom muxtx 3 AT+CGFUNC=1,0
Enable:
simcom muxtx 3 AT+CGFUNC=1,1
There is also AT+CLEDITST, but I can’t seem to make that work.
Black case should be darker and let light through. The 3D printed prototypes are very transparent.
> On 19 Dec 2017, at 3:37 PM, Michael Balzer <dexter at expeedo.de> wrote:
> Greg,
> the blue LED is not controllable, it's acting as a Zener diode in the voltage regulation, i.e. it flashes when draining a too high voltage.
> So, as a workaround you could replace it by a standard Zener diode, just needs to have the same breakdown voltage.
> But I don't think the black case lets through much light -- Mark?
> Am 19.12.2017 um 05:47 schrieb Greg D.:
>> Hi folks,
>> The "real" module's case is black, but how well does it block light?
>> I'm thinking about the modem's LED, which flashes pretty brightly in the
>> proto (white) case. In a dark parking lot, it could attract unwanted
>> attention. (Or, perhaps simulate a car alarm, which wouldn't
>> necessarily be bad...)
>> If the LED is visible externally, is there a way to disable it?
>> Greg
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20171221/80589ec2/attachment.html>
