[Ovmsdev] chatty v2 server comms
Tom Parker tom at carrott.org
Tue Dec 19 14:40:47 HKT 2017
At least during charging this appears to be working better, 2 messages
per minute for the  most part. I always have a client connected as my
python client is always connected waiting for messages.
These logs are with 63b87c3f46d5af9eaf49739aa3179c4d026aa3de + a hack to
ignore changes in the ms_v_bat_12v_voltage metric (and also nissan leaf
remote control changes but they don't affect the telemetry). I'm
ignoring the 12v because it appears to have only 3 decimal significant
figures of signal and we're monitoring changes on 3 additional
significant figures of noise. The following are the values every minute
while the car is charging the traction battery and the 12v system is
powered by the on board DC-DC.
13.1374
13.1923
13.1813
13.1264
13.1209
13.1978
13.1044
13.1154
13.1538
13.2418
13.1593
13.1813
13.1484
13.1813
13.1374
13.1813
13.1813
It's probably worth storing and even transmitting 4 significant figures,
as you can see trends in the noise much more clearly than the v2's 100mV
steps, but we shouldn't trigger notifications on the noise. We could
also look at averaging or taking the median to increase the signal to
noise ratio.
The full log below shows the few minutes as I arrived home and it
connected to the wifi (gsm is too unstable to use) and then I plugged in
and started charging.
2017-12-19 05:09:33,21226,'#79 A got login'
2017-12-19 05:10:01,21292,'#37 C got login'
2017-12-19 05:10:01,21293,'#37 C rx msg S
50,K,0,0,stopped,standard,42,0,0,0,0,0,13,21,0,0,0,0,63.22,0,0,0,0,-1,0,0,0,0,0,0,0,0.00,378.50,96'
2017-12-19 05:10:01,21294,'#37 C rx msg D
128,0,5,0,0,27,0,70,0,460,21,1,1,1,12.5934,0,0,0,0,0'
2017-12-19 05:10:02,21295,'#37 C rx msg L 0,0,0,0,0,0,0,0,0,0,0'
2017-12-19 05:10:02,21296,'#37 C rx msg W 0,0,0,0,0,0,0,0,0'
2017-12-19 05:10:03,21297,'#37 C rx msg F 3.0.0/factory/main build (idf
v2.1-20-g88ab5d4) Dec 18 2017 09:50:21,,0,1,NL,redacted'
2017-12-19 05:10:03,21298,'#37 C rx msg S
2017-12-19 05:10:03,21299,'#37 C rx msg D
2017-12-19 05:10:04,21300,'#37 C rx msg L 0,0,0,0,0,0,0,0,0,0,0'
2017-12-19 05:10:04,21301,'#37 C rx msg W 0,0,0,0,0,0,0,0,0'
2017-12-19 05:10:05,21302,'#37 C rx msg F 3.0.0/factory/main build (idf
2017-12-19 05:10:22,21360,'#37 C rx msg S
50,K,511,0,charging,standard,42,0,17,0,0,0,3,1,0,0,0,0,63.22,0,0,0,0,-1,0,0,0,0,0,0,0,-0.00,511.50,96'
2017-12-19 05:10:22,21361,'#37 C rx msg D
156,0,5,0,0,27,0,70,0,477,22,1,1,1,12.6758,0,0,0,0,0'
2017-12-19 05:10:23,21362,'#37 C rx msg S
50,K,378,0,charging,standard,42,0,10,0,0,0,3,1,0,0,0,0,63.22,0,0,0,0,-1,0,0,0,0,0,0,0,-0.00,378.50,96'
2017-12-19 05:10:23,21363,'#37 C rx msg S
50,K,378,0,charging,standard,42,0,10,0,0,0,3,1,0,0,0,0,63.13,0,0,0,0,-1,0,0,0,0,0,0,0,-0.00,378.50,96'
2017-12-19 05:10:24,21364,'#37 C rx msg S
2017-12-19 05:10:27,21372,'#37 C rx msg S
2017-12-19 05:11:19,21481,'#37 C rx msg S
50,K,379,5,charging,standard,42,0,10,0,0,0,3,1,0,0,0,0,63.13,0,0,0,0,-1,0,0,0,0,0,0,0,-0.00,379.50,96'
2017-12-19 05:11:19,21482,'#37 C rx msg D
156,0,5,0,0,27,0,80,0,521,22,1,1,1,13.1044,0,0,0,0,0'
2017-12-19 05:11:39,21537,'#37 C rx msg D
92,0,5,0,0,27,0,90,0,558,22,0,1,1,13.1374,0,0,0,0,0'
2017-12-19 05:12:03,21599,'#37 C rx msg S
50,K,379,4,charging,standard,42,0,10,1,0,0,3,1,0,0,0,0,63.13,0,0,0,0,-1,0,0,0,0,0,0,0,-0.00,379.50,96'
2017-12-19 05:12:03,21602,'#37 C rx msg D
92,0,5,0,0,27,0,90,0,582,22,0,1,1,13.1813,0,0,0,0,0'
2017-12-19 05:13:04,21745,'#37 C rx msg S
50,K,380,4,charging,standard,42,0,10,2,0,0,3,1,0,0,0,0,63.13,0,0,0,0,-1,0,0,0,0,0,0,0,-0.00,380.00,96'
2017-12-19 05:13:04,21746,'#37 C rx msg D
92,0,5,0,0,27,0,100,0,643,22,0,1,1,13.1648,0,0,0,0,0'
2017-12-19 05:14:05,21870,'#37 C rx msg S
50,K,380,4,charging,standard,42,0,10,3,0,0,3,1,0,0,0,0,63.13,0,0,0,0,-1,0,0,0,0,0,0,0,-0.00,380.00,96'
2017-12-19 05:14:07,21879,'#37 C rx msg D
92,0,5,0,0,27,0,110,0,704,22,0,1,1,13.1813,0,0,0,0,0'
2017-12-19 05:15:13,22039,'#37 C rx msg S
50,K,380,3,charging,standard,42,0,10,4,0,0,3,1,0,0,0,0,63.13,0,0,0,0,-1,0,0,0,0,0,0,0,-0.00,380.50,96'
2017-12-19 05:15:13,22040,'#37 C rx msg D
92,0,5,0,0,27,0,120,0,765,23,0,1,1,13.1593,0,0,0,0,0'
2017-12-19 05:15:51,22142,'#15 A timeout due app due to inactivity'
2017-12-19 05:15:54,22146,'#15 A got login'
2017-12-19 05:16:07,22183,'#37 C rx msg S
51,K,380,5,charging,standard,42,0,10,5,0,0,3,1,0,0,0,0,63.13,0,0,0,0,-1,0,0,0,0,0,0,0,-0.00,380.50,96'
2017-12-19 05:16:07,22184,'#37 C rx msg D
92,0,5,0,0,27,0,130,0,826,23,0,1,1,13.1813,0,0,0,0,0'
2017-12-19 05:17:08,22324,'#37 C rx msg S
51,K,380,4,charging,standard,42,0,10,6,0,0,3,1,0,0,0,0,63.13,0,0,0,0,-1,0,0,0,0,0,0,0,-0.00,380.50,96'
2017-12-19 05:17:08,22325,'#37 C rx msg D
92,0,5,0,0,27,0,140,0,887,23,0,1,1,13.1813,0,0,0,0,0'
2017-12-19 05:18:09,22450,'#37 C rx msg S
51,K,380,4,charging,standard,43,0,10,7,0,0,3,1,0,0,0,0,63.13,0,0,0,0,-1,0,0,0,0,0,0,0,-0.00,380.50,96'
2017-12-19 05:18:12,22457,'#37 C rx msg D
92,0,5,0,0,27,0,150,0,948,23,0,1,1,13.1923,0,0,0,0,0'
2017-12-19 05:19:10,22589,'#37 C rx msg S
51,K,380,4,charging,standard,43,0,10,8,0,0,3,1,0,0,0,0,63.13,0,0,0,0,-1,0,0,0,0,0,0,0,-0.00,380.50,96'
2017-12-19 05:19:10,22590,'#37 C rx msg D
92,0,5,0,0,27,0,160,0,1009,23,0,1,1,13.1593,0,0,0,0,0'
2017-12-19 05:20:11,22725,'#37 C rx msg S
51,K,381,4,charging,standard,43,0,10,9,0,0,3,1,0,0,0,0,63.13,0,0,0,0,-1,0,0,0,0,0,0,0,-0.00,381.00,96'
2017-12-19 05:20:11,22726,'#37 C rx msg D
92,0,5,0,0,27,0,170,0,1070,23,0,1,1,13.1703,0,0,0,0,0'
2017-12-19 05:21:12,22870,'#37 C rx msg S
51,K,381,4,charging,standard,43,0,10,10,0,0,3,1,0,0,0,0,63.13,0,0,0,0,-1,0,0,0,0,0,0,0,-0.00,381.00,96'
2017-12-19 05:21:12,22871,'#37 C rx msg D
92,0,5,0,0,27,0,180,0,1131,24,0,1,1,13.1813,0,0,0,0,0'
2017-12-19 05:22:13,22999,'#37 C rx msg S
51,K,381,4,charging,standard,43,0,10,11,0,0,3,1,0,0,0,0,63.13,0,0,0,0,-1,0,0,0,0,0,0,0,-0.00,381.00,96'
2017-12-19 05:22:13,23001,'#37 C rx msg D
92,0,5,0,0,27,0,190,0,1192,24,0,1,1,13.1319,0,0,0,0,0'
2017-12-19 05:23:14,23114,'#37 C rx msg S
52,K,381,4,charging,standard,43,0,10,12,0,0,3,1,0,0,0,0,63.13,0,0,0,0,-1,0,0,0,0,0,0,0,-0.00,381.00,96'
2017-12-19 05:23:14,23115,'#37 C rx msg D
92,0,5,0,0,27,0,200,0,1253,24,0,1,1,13.1813,0,0,0,0,0'
2017-12-19 05:24:15,23235,'#37 C rx msg S
52,K,381,4,charging,standard,43,0,10,13,0,0,3,1,0,0,0,0,63.13,0,0,0,0,-1,0,0,0,0,0,0,0,-0.00,381.00,96'
2017-12-19 05:24:15,23236,'#37 C rx msg D
92,0,5,0,0,27,0,210,0,1314,25,0,1,1,13.2033,0,0,0,0,0'
2017-12-19 05:25:16,23394,'#37 C rx msg S
52,K,381,4,charging,standard,43,0,10,14,0,0,3,1,0,0,0,0,63.13,0,0,0,0,-1,0,0,0,0,0,0,0,-0.00,381.00,96'
2017-12-19 05:25:16,23395,'#37 C rx msg D
92,0,5,0,0,27,0,220,0,1375,25,0,1,1,13.1978,0,0,0,0,0'
2017-12-19 05:26:17,23536,'#37 C rx msg S
52,K,381,5,charging,standard,44,0,10,15,0,0,3,1,0,0,0,0,63.13,0,0,0,0,-1,0,0,0,0,0,0,0,-0.00,381.50,96'
2017-12-19 05:26:17,23538,'#37 C rx msg D
92,0,5,0,0,27,0,230,0,1436,25,0,1,1,13.2143,0,0,0,0,0'
