[Ovmsdev] Some Bugs
Sun Dec 17 11:10:43 HKT 2017
I too have started to see these under-voltage warnings. I’m wondering if it is something to do with the work we recently did to enable GPS. It doesn’t seem to be a problem with powered HUBs or high power boards, so is most likely an actual low voltage condition.
> On 16 Dec 2017, at 5:59 PM, Tom Parker <tom at carrott.org> wrote:
> Hi all,
> Master doesn't compile with the default sdkconfig when you answer no to all the questions:
> /vagrant/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_ota.cpp: In member function 'void OvmsOTA::AutoFlashSD(std::__cxx11::string, void*)':
> /vagrant/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_ota.cpp:432:18: error: 'class Peripherals' has no member named 'm_sdcard'
> If you add in CONFIG_OVMS_COMP_SDCARD=y then it compiles.
> There is a buffer overflow in the v2 command handling because we call strncpy with the length of the string not the (larger) length of the receiving buffer and so the null terminator is not copied. Later we read beyond the copied buffer because there is no null terminator. This often crashes the android client as it's not expecting junk data after the reply. The following encryption code doesn't include the null terminator either but I think that might be ok?
> I've sent a pull request to fix the strncpy.
> I've found the SIMCOM modem is very unstable when connected to my laptop via an unpowered USB hub. I see under-voltage warnings so I wonder if there isn't enough power? It seems stable when connected directly to my laptop. When it the modem reboots, the esp32 crashes too. I'm not sure if this is because it also ran out of power or because it is sad the network went away:
>  (77496) SIMCOM ppp rx: 4b e5 0a aa c7 0f 1a d3 90 1f 26 03 4c 1c 00 00 K.........&.L...
> D (77506) SIMCOM ppp rx: 19 ac 50 18 39 08 05 3c 00 00 6d 2f 47 45 71 44 ..P.9..<..m/GEqD
> D (77506) SIMCOM ppp rx: 78 41 78 51 3d 3d 0d 0a d6 17 7e                xAxQ==....~
> I (77536) ovms-server-v2: Incoming Msg: MP-0 Z2
> I (77536) ovms-server-v2: One or more peers have connected
> I (77536) ovms-server-v2: Send MP-0 S0,K,0,0,stopped,standard,0,0,0,0,0,0,0,21,0,0,0,0,0.00,0,0,0,0,-1,0,0,0,0,0,0,0,0.00,0.00,0
> I (77546) ovms-server-v2: Send MP-0 D64,0,5,0,0,0,0,0,0,77,0,0,0,0,0.967033,0,0,0,0,0
> I (77556) ovms-server-v2: Send MP-0 L0,0,0,0,0,0,0,0,0,0,0
> I (77566) ovms-server-v2: Send MP-0 W0,0,0,0,0,0,0,0,0
> I (77576) ovms-server-v2: Send MP-0 F3.0.0/factory/main build (idf v2.1-20-g88ab5d4) Dec 16 2017 09:23:50,,12,1,NL,VodafoneNZ Hologram
> D (77936) SIMCOM rx: f9 0d ff 4b 0d 0a 55 4e 44 45 52 2d 56 4f 4c 54 ...K..UNDER-VOLT
> D (77936) SIMCOM rx: 41 47 45 20 57 41 52 4e 4e 49 4e 47 20 50 4f 57 AGE WARNNING POW
> D (77946) SIMCOM rx: 45 52 20 44 4f 57 4e 0d 0a 9b f9 f9 11 ff 4b 0d ER DOWN.......K.
> D (77946) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=9b, LEN=43)
> D (77946) gsm-mux: ChanProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, LEN=40, IFP=3)
> D (77946) SIMCOM line: 55 4e 44 45 52 2d 56 4f 4c 54 41 47 45 20 57 41 UNDER-VOLTAGE WA
> D (77946) SIMCOM line: 52 4e 4e 49 4e 47 20 50 4f 57 45 52 20 44 4f 57 RNNING POWER DOW
> D (77946) SIMCOM line: 4e                                              N
> D (77946) SIMCOM rx: 0a 55 4e 44 45 52 2d 56 4f 4c 54 41 47 45 20 57 .UNDER-VOLTAGE W
> D (77946) SIMCOM rx: 41 52 4e 4e 49 4e 47 20 50 4f 57 45 52 20 44 4f ARNNING POWER DO
> D (77946) SIMCOM rx: 57 4e 0d 0a 96 f9 f9 0d ff 45 0d 0a 73 74 61 72 WN.......E..star
> D (77946) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=96, LEN=43)
> D (77946) gsm-mux: ChanProcessFrame(CHAN=4, ADDR=11, CTRL=ff, LEN=40, IFP=3)
> D (77946) SIMCOM rx: 74 69 6e 67 20 70 6f 77 65 72 20 6f 66 66 20 74 ting power off t
> D (77946) SIMCOM rx: 68 65 20 6d 6f 64 75 6c 65 21 0d 0a 71 f9 f9 11 he module!..q...
> D (77946) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=71, LEN=40)
> D (77946) gsm-mux: ChanProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, LEN=37, IFP=3)
> D (77946) SIMCOM line: 73 74 61 72 74 69 6e 67 20 70 6f 77 65 72 20 6f starting power o
> D (77946) SIMCOM line: 66 66 20 74 68 65 20 6d 6f 64 75 6c 65 21       ff the module!
> D (77946) SIMCOM rx: ff 45 0d 0a 73 74 61 72 74 69 6e 67 20 70 6f 77 .E..starting pow
> D (77946) SIMCOM rx: 65 72 20 6f 66 66 20 74 68 65 20 6d 6f 64 75 6c er off the modul
> D (77946) SIMCOM rx: 65 21 0d 0a 7c f9                               e!..|.
> D (77946) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=7c, LEN=40)
> D (77946) gsm-mux: ChanProcessFrame(CHAN=4, ADDR=11, CTRL=ff, LEN=37, IFP=3)
> D (78216) SIMCOM ppp tx: 7e ff 03 80 57 01 01 00 0e 01 0a 85 b9 57 2f be ~...W........W/.
> D (78216) SIMCOM ppp tx: 63 a0 85 80 17 7e                               c....~
> D (78216) SIMCOM tx: f9 09 ff 2d 7e ff 03 80 57 01 01 00 0e 01 0a 85 ...-~...W.......
> D (78216) SIMCOM tx: b9 57 2f be 63 a0 85 80 17 7e f5 f9             .W/.c....~..
> D (78566) SIMCOM rx: f9 09 ff cb 7e 21 45 00 00 60 92 81 40 00 2d 06 ....~!E..`.. at .-.
> D (78566) SIMCOM rx: e0 ed bc 8a 4b e5 0a aa c7 0f 1a d3 90 1f 26 03 ....K.........&.
> D (78566) SIMCOM rx: 4b e4 00 00 19 ac 50 18 39 08 79 ae 00 00 4d 50 K.....P.9.y...MP
> D (78576) SIMCOM rx: 2d 53 20 30 20 6a 79 30 32 65 51 6b 7a 55 52 4d -S 0 jy02eQkzURM
> D (78576) SIMCOM rx: 70 73 49 41 36 56 59 48 6e 39 59 20 58 72 5a 6b psIA6VYHn9Y XrZk
> D (78576) SIMCOM rx: 64 71 48 7a 54 38 6a 77 74 44 47 46 66 6a 52 73 dqHzT8jwtDGFfjRs
> D (78576) SIMCOM rx: 79 77 3d 3d 0d 0a 58 bf 7e b9 f9                yw==..X.~..
> D (78576) gsm-mux: ProcessFrame(CHAN=2, ADDR=09, CTRL=ff, FCS=b9, LEN=107)
> D (78576) gsm-mux: ChanProcessFrame(CHAN=2, ADDR=09, CTRL=ff, LEN=104, IFP=3)
> D (78576) SIMCOM ppp rx: 7e 21 45 00 00 60 92 81 40 00 2d 06 e0 ed bc 8a ~!E..`.. at .-.....
> D (78576) SIMCOM ppp rx: 4b e5 0a aa c7 0f 1a d3 90 1f 26 03 4b e4 00 00 K.........&.K...
> D (78586) SIMCOM ppp rx: 19 ac 50 18 39 08 79 ae 00 00 4d 50 2d 53 20 30 ..P.9.y...MP-S 0
> D (78586) SIMCOM ppp rx: 20 6a 79 30 32 65 51 6b 7a 55 52 4d 70 73 49 41  jy02eQkzURMpsIA
> D (78586) SIMCOM ppp rx: 36 56 59 48 6e 39 59 20 58 72 5a 6b 64 71 48 7a 6VYHn9Y XrZkdqHz
> D (78586) SIMCOM ppp rx: 54 38 6a 77 74 44 47 46 66 6a 52 73 79 77 3d 3d T8jwtDGFfjRsyw==
> D (78596) SIMCOM ppp rx: 0d 0a 58 bf 7e                                  ..X.~
> D (78596) SIMCOM ppp tx: 7e 21 45 00 00 28 00 08 00 00 ff 06 e1 9e 0a aa ~!E..(..........
> D (78596) SIMCOM ppp tx: c7 0f bc 8a 4b e5 90 1f 1a d3 00 00 1a 32 26 03 ....K........2&.
> D (78596) SIMCOM ppp tx: 4c 2a 50 10 16 8a 87 cf 00 00 22 59 7e          L*P......."Y~
> D (78596) SIMCOM tx: f9 09 ff 5b 7e 21 45 00 00 28 00 08 00 00 ff 06 ...[~!E..(......
> D (78596) SIMCOM tx: e1 9e 0a aa c7 0f bc 8a 4b e5 90 1f 1a d3 00 00 ........K.......
> D (78596) SIMCOM tx: 1a 32 26 03 4c 2a 50 10 16 8a 87 cf 00 00 22 59 .2&.L*P......."Y
> D (78596) SIMCOM tx: 7e 45 f9                                        ~E.
> D (78986) SIMCOM rx: f9 09 ff 23 7e ff 7d 23 c0 21 7d 25 7d 23 7d 20 ...#~.}#.!}%}#}
> D (78986) SIMCOM rx: 7d 24 85 72 7e 1f f9 f9 0d ff 2f 0d 0a 2b 50 50 }$.r~...../..+PP
> D (78986) gsm-mux: ProGuru Meditation Error of type LoadProhibited occurred on core  1. Exception was unhandled.
> Register dump:
> PC      : 0x4017fd75  PS      : 0x00060b30  A0      : 0x8017fdb6 A1      : 0x3ffcf030
> 0x4017fd75: ip4_route at /home/ubuntu/esp/esp-idf/components/lwip/core/ipv4/ip4.c:250 (discriminator 2)
> A2      : 0x0000f01d  A3      : 0x00000000  A4      : 0x3ffeb04c A5      : 0x3f429a88
> A6      : 0x00000008  A7      : 0x3ffcf258  A8      : 0x8017fd69 A9      : 0x3ffcf010
> A10     : 0x00000000  A11     : 0x00000000  A12     : 0x3ffdcd3c A13     : 0x3ffcf240
> A14     : 0x00000004  A15     : 0xab9423a7  SAR     : 0x00000018 EXCCAUSE: 0x0000001c
> EXCVADDR: 0x0000f0d2  LBEG    : 0x4000c349  LEND    : 0x4000c36b LCOUNT  : 0x00000000
> Backtrace: 0x4017fd75:0x3ffcf030 0x4017fdb3:0x3ffcf050 0x4017dfa2:0x3ffcf070 0x40178617:0x3ffcf0b0 0x40178639:0x3ffcf0e0 0x401786da:0x3ffcf100 0x40178b38:0x3ffcf120 0x4017c272:0x3ffcf140 0x4017c2b3:0x3ffcf160 0x40184cdd:0x3ffcf180 0x401850a1:0x3ffcf1a0 0x401850e8:0x3ffcf1c0 0x401894f9:0x3ffcf1e0 0x40184fd8:0x3ffcf200 0x4018c9ce:0x3ffcf220 0x4018ca0a:0x3ffcf240 0x401880dd:0x3ffcf260 0x40189b19:0x3ffcf280 0x40189bc4:0x3ffcf2a0 0x40187eff:0x3ffcf2c0 0x40184b05:0x3ffcf2e0 0x401a2be8:0x3ffcf310 0x401a2d35:0x3ffcf330 0x401731c9:0x3ffcf350
> 0x4017fdb3: ip4_route_src at /home/ubuntu/esp/esp-idf/components/lwip/core/ipv4/ip4.c:159
> 0x4017dfa2: tcp_rst at /home/ubuntu/esp/esp-idf/components/lwip/core/tcp_out.c:1336 (discriminator 4)
> 0x40178617: tcp_abandon at /home/ubuntu/esp/esp-idf/components/lwip/core/tcp.c:1630
> 0x40178639: tcp_abort at /home/ubuntu/esp/esp-idf/components/lwip/core/tcp.c:1630
> 0x401786da: tcp_netif_ipv4_addr_changed_pcblist at /home/ubuntu/esp/esp-idf/components/lwip/core/tcp.c:1630
> 0x40178b38: tcp_netif_ipv4_addr_changed at /home/ubuntu/esp/esp-idf/components/lwip/core/tcp.c:1947
> 0x4017c272: netif_set_ipaddr at /home/ubuntu/esp/esp-idf/components/lwip/core/netif.c:452
> 0x4017c2b3: netif_set_addr at /home/ubuntu/esp/esp-idf/components/lwip/core/netif.c:330
> 0x40184cdd: cifaddr at /home/ubuntu/esp/esp-idf/components/lwip/netif/ppp/ppp.c:704
> 0x401850a1: ipcp_clear_addrs at /home/ubuntu/esp/esp-idf/components/lwip/netif/ppp/ipcp.c:2192
> 0x401850e8: ipcp_down at /home/ubuntu/esp/esp-idf/components/lwip/netif/ppp/ipcp.c:2156
> 0x401894f9: fsm_lowerdown at /home/ubuntu/esp/esp-idf/components/lwip/netif/ppp/fsm.c:146
> 0x40184fd8: ipcp_lowerdown at /home/ubuntu/esp/esp-idf/components/lwip/netif/ppp/ipcp.c:687
> 0x4018c9ce: upper_layers_down at /home/ubuntu/esp/esp-idf/components/lwip/netif/ppp/auth.c:715
> 0x4018ca0a: link_down at /home/ubuntu/esp/esp-idf/components/lwip/netif/ppp/auth.c:701
> 0x401880dd: lcp_down at /home/ubuntu/esp/esp-idf/components/lwip/netif/ppp/lcp.c:2341
> 0x40189b19: fsm_rtermreq at /home/ubuntu/esp/esp-idf/components/lwip/netif/ppp/fsm.c:597
> 0x40189bc4: fsm_input at /home/ubuntu/esp/esp-idf/components/lwip/netif/ppp/fsm.c:369
> 0x40187eff: lcp_input at /home/ubuntu/esp/esp-idf/components/lwip/netif/ppp/lcp.c:513
> 0x40184b05: ppp_input at /home/ubuntu/esp/esp-idf/components/lwip/netif/ppp/ppp.c:704
> 0x401a2be8: pppos_input at /home/ubuntu/esp/esp-idf/components/lwip/netif/ppp/pppos.c:578
> 0x401a2d35: pppos_input_sys at /home/ubuntu/esp/esp-idf/components/lwip/netif/ppp/pppos.c:460 (discriminator 3)
> 0x401731c9: tcpip_thread at /home/ubuntu/esp/esp-idf/components/lwip/api/tcpip.c:474
> Rebooting...
> ets Jun  8 2016 00:22:57
