[Ovmsdev] Special cable for Kia Soul EV for OVMS V3.
Geir Øyvind Vælidalo
geir at validalo.net
Wed Dec 13 17:14:49 HKT 2017
Jepp! That is the ultimate goal 🙂
However, I’m a realistic pessimist.
Geir
> 13. des. 2017 kl. 08:55 skrev Mark Webb-Johnson <mark at webb-johnson.net>:
>> climate control is on the M-bus
> Pre-heat! :-)
>> On 13 Dec 2017, at 3:52 PM, Geir Øyvind Vælidalo <geir at validalo.net <mailto:geir at validalo.net>> wrote:
>> Great 🙂
>> I’ve already ordered a pigtail cable, so we’ll see what we can find out.
>> The navigation and climate control is on the M-bus, so I hope we will find something useful on that bus.
>> Geir
>> Sendt fra min iPhone
>> 13. des. 2017 kl. 02:22 skrev Jason Perkins <perkins.jason at gmail.com <mailto:perkins.jason at gmail.com>>:
>>> The Fiat 500e uses the same pins for 2 of its CANs, so the same cable would be useful for more than just the Kia. (Assuming there’s useful info on both buses)
>>> -J
>>> On Tue, Dec 12, 2017 at 7:54 PM Mark Webb-Johnson <mark at openvehicles.com <mailto:mark at openvehicles.com>> wrote:
>>> Relatively easy. I just give them pinouts, some money, and a week later a bunch of cables arrive.
>>> There is a minimum order quantity of 50 cables from the supplier, so it has to be justifiable.
>>> Perhaps best to have a look at that M-can bus (with a hand-built cable), and see if there is anything on it that makes this worthwhile. You can find OBDII pigtails on AliExpress/eBay/Amazon that make this relatively simple (only need to solder the DB9 end).
>>>> On 13 Dec 2017, at 4:09 AM, Geir Øyvind Vælidalo <geir at validalo.net <mailto:geir at validalo.net>> wrote:
>>>> Hi,
>>>> We might need a special cable for the Kia Soul EV, as it has two CAN-buses on the diagnostic port and it doesn’t match the ODB2-cable nor the Nissan Leaf-cable.
>>>> Then C-can uses the standard pins 6 and 14, but the M-can uses pins 1 (high) and 9 (low).
>>>> The M-can should be mapped to CAN1_H (Pin 5 on DB9) and CAN1_L(Pin 4 on DB9):
>>>> J1962-M DB9-F Signal
>>>> 1 5 CAN-1H (M-can High)
>>>> 4 3 Chassis/Power GND
>>>> 6 7 CAN-0H (C-can high)
>>>> 9 4 CAN-1L (M-can Low)
>>>> 14 2 CAN-0L (C-can low)
>>>> 16 9 +12V Vehicle Power
>>>> I don’t use the M-can at the moment, and I’m not sure I will, but if I do we might need to have a special cable made for the Soul EV.
>>>> Is that something that is easy to fix?
>>>> Regards,
>>>> Geir
>>>> OvmsDev mailing list
>>>> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>
>>> Jason Perkins 313 355 0085 Sent from my iPhone
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20171213/412a4029/attachment.html>
