[Ovmsdev] Network Manager Ideas
Wed Dec 13 06:56:49 HKT 2017
Oh, I see.
Yes, Register in the class init was what I anticipated. So you could configure the vehicle before starting it.
Same as OVMS server v2, for example. Parameters are registered even if you don’t start the module.
> On 13 Dec 2017, at 6:48 AM, Michael Balzer <dexter at expeedo.de> wrote:
> Another option would be to do the RegisterParam() call in the framework registration class, .i.e. OvmsVehicleRenaultTwizyInit. This would assure access rights
> are set on boot if the module is included, regardless of it being actually started.
> That smells a bit like breaking the factory class pattern, but seems to be an alternative.
>> Am 12.12.2017 um 23:35 schrieb Michael Balzer:
>> It's necessary if we want to be able to see configs of not yet loaded modules, i.e. vehicles. Without the persistance the configs are not readable before the
>> module is actually loaded by the user -- so a module configuration can also not be checked without loading the module.
>> That was my reason to change this: without persistance, I cannot see my Twizy configuration after boot before issueing "vehicle module RT". If a part of my
>> config needs to be changed before starting the module, I cannot see what I've set before.
>> You're right in the special meaning of instance names prefixed with "#" -- these should not be allowed for this serialization form. I chose "#" as that's a
>> typical comment line character, and I thought names like this will normally not be used. I'll add a check to prevent using instance names colliding with that
>> pattern, if you agree on the basic solution.
>>> Am 12.12.2017 um 23:19 schrieb Mark Webb-Johnson:
>>> It is the second one I am not sure is necessary.
>>> If access is controlled by the Register, why persist at all? What would happen if the permissions in Register were changed? What would happen if an instance "#access" was set?
>>> Regards, Mark
>>>> On 13 Dec 2017, at 5:54 AM, Michael Balzer <dexter at expeedo.de> wrote:
>>>> I've pushed two commits regarding this, the first only fixed the primary problem of not setting the access rights again on RegisterParam() after loading the
>>>> config cache.
>>>> The second one adds storage persistance, as I think it's OK to persist this info. The RegisterParam() call will always set the current access rights as
>>>> programmed, this is only meant to restore the latest access rights of parameters registered by loadable modules like vehicles.
>>>> So I think this should be OK?
>>>> Regards,
>>>> Michael
>>>>> Am 12.12.2017 um 22:45 schrieb Mark Webb-Johnson:
>>>>> Michael,
>>>>> I don't think this is correct/necessary.
>>>>> The access rights are provided in the Register command, when the parameter is registered. This is done each and every time. We don't need to persist this to /store file system.
>>>>> There was an issue with load order - where parameters could be loaded before the Register function call. Perhaps that is what is causing the bug you are seeing? The code was fixed to work around this, but perhaps it is not setting the access rights correctly in that case?
>>>>> Regards, Mark
>>>>>> On 13 Dec 2017, at 3:32 AM, Michael Balzer <dexter at expeedo.de> wrote:
>>>>>>> Am 12.12.2017 um 20:12 schrieb Michael Balzer:
>>>>>>> Btw: I've always registered my config "x.rt" as readable, but "config list x.rt" will no longer show any values. I'm pretty sure it did before.
>>>>>> Found & fixed, the access rights wouldn't be restored on loading the config.
>>>>>> Regards,
>>>>>> Michael
>>>>>> OvmsDev mailing list
