[Ovmsdev] Network Manager Ideas
Wed Dec 13 05:45:47 HKT 2017
Michael,
I don't think this is correct/necessary.
The access rights are provided in the Register command, when the parameter is registered. This is done each and every time. We don't need to persist this to /store file system.
There was an issue with load order - where parameters could be loaded before the Register function call. Perhaps that is what is causing the bug you are seeing? The code was fixed to work around this, but perhaps it is not setting the access rights correctly in that case?
> On 13 Dec 2017, at 3:32 AM, Michael Balzer <dexter at expeedo.de> wrote:
>> Am 12.12.2017 um 20:12 schrieb Michael Balzer:
>> Btw: I've always registered my config "x.rt" as readable, but "config list x.rt" will no longer show any values. I'm pretty sure it did before.
> Found & fixed, the access rights wouldn't be restored on loading the config.
