[Ovmsdev] GPS / NMEA integration
Wed Dec 13 02:56:21 HKT 2017
Am 11.12.2017 um 06:47 schrieb Mark Webb-Johnson:
> Under the principle of ‘keep everything powered off unless explicitely asked to power it on’, I think we should default enable.gps and enable.gpstime to FALSE.
> Thinking about the arrangement of a vehicle requiring GPS, perhaps this can be signalled somehow in vehicle.{h,cpp}? Have the vehicle module define there that
> it requires modem GPS and/or GPSTIME, and then have the nmea module enable appropriately? We can still retain modem/enable.gps(time) for explicitly enabling
> (I had a use case for this when a roadster owner on v2 had a broken car GPS, but the v2 tesla_roadster module doesn't enable the modem gps).
> So the logic in nmea becomes: If ((vehicle module needs modem GPS)||(modem enable.gps)) Then enable gps.
The SIMCOM module now listens to these events:
* vehicle.require.gps
* vehicle.release.gps
* vehicle.require.gpstime
* vehicle.release.gpstime
If a vehicle needs GPS provided by the system, it does for example:
MyEvents.SignalEvent("vehicle.require.gps", NULL);
MyEvents.SignalEvent("vehicle.require.gpstime", NULL);
The SIMCOM module will in turn automatically power on and start the GPS subsystem as necessary, regardless of the "enable.gps" config. The signal normally will
be added to the vehicle init but can be sent any time. The release signals can be used to shutdown the service when it's no longer needed.
The "simcom status" command shows both enabled & required status.
OVMS > simcom status
SIMCOM
Network Registration: NotRegistered
State: PoweredOff
Ticker: 3
User Data: 0
Mux Open Channels: 0
PPP Not Connected
PPP Last Error: Undefined
GPS: *disabled*
GPS time: disabled
NMEA (GPS/GLONASS) Not Connected
OVMS > vehicle module RT
I (46062) v-renaulttwizy: Renault Twizy vehicle module
I (46062) events: Signal(power.can1.on)
I (46072) v-renaulttwizy: battmon subsystem init
I (46072) v-renaulttwizy: pwrmon subsystem init
I (46082) events: Signal(*vehicle.require.gps*)
I (46082) events: Signal(power.simcom.on)
I (46082) simcom: State: Enter PoweringOn state
I (46082) simcom: Power Cycle
I (46562) events: Signal(vehicle.charge.mode)
I (46562) events: Signal(vehicle.charge.state)
I (47082) events: Signal(vehicle.require.gpstime)
I (52562) simcom: State: Enter PoweredOn state
I (72572) simcom: State: Enter MuxStart state
I (72572) gsm-mux: Start MUX
I (72572) gsm-mux: StartChannel(0)
I (72572) gsm-mux: Channel #0 is open
I (72572) gsm-mux: StartChannel(1)
I (72582) gsm-mux: Channel #1 is open
I (72582) gsm-mux: StartChannel(2)
I (72592) gsm-mux: Channel #2 is open
I (72592) gsm-mux: StartChannel(3)
I (72602) gsm-mux: Channel #3 is open
I (72602) gsm-mux: StartChannel(4)
I (72612) gsm-mux: Channel #4 is open
I (73562) simcom: State: Enter NetWait state
I (73562) gsm-nmea: Startup
I (80182) events: Signal(*gps.lock.acquired*)
I (80192) notify: Raise text data: RT-GPS-Log,0,86400,51.30230713,7.38993549,332,0,0,1,120,-97,0,0,0,0,0,0,40,0,0,1.000,1.000,0,0
I (80192) events: Signal(system.modem.gotgps)
SIMCOM
Network Registration: RegisteredRoaming
State: NetMode
Ticker: 107
User Data: 0
Mux Open Channels: 4
PPP Connected on channel: #2
PPP Last Error: None
GPS: disabled, *required*
GPS time: disabled, required
NMEA (GPS/GLONASS) Connected on channel: #1
>> On 10 Dec 2017, at 10:33 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>> Works, pushed:
>> OVMS > config list modem
>> modem
>> apn: hologram
>> apn.password:
>> apn.user:
>> * enable.gps: yes**
>> ** enable.gpstime: yes*
>> enable.net <http://enable.net>: yes
>> enable.sms: yes
>> OVMS > power simcom on
>> Power mode of simcom is now on
>> I (28084) events: Signal(power.simcom.on)
>> I (28084) simcom: State: Enter PoweringOn state
>> I (28084) simcom: Power Cycle
>> I (34414) simcom: State: Enter PoweredOn state
>> I (53514) simcom: State: Enter MuxMode state
>> I (53514) gsm-mux: Start MUX
>> I (53514) gsm-mux: StartChannel(0)
>> I (53524) gsm-mux: Channel #0 is open
>> I (53524) gsm-mux: StartChannel(1)
>> I (53534) gsm-mux: Channel #1 is open
>> I (53534) gsm-mux: StartChannel(2)
>> I (53544) gsm-mux: Channel #2 is open
>> I (53544) gsm-mux: StartChannel(3)
>> I (53544) gsm-mux: Channel #3 is open
>> I (53544) gsm-mux: StartChannel(4)
>> I (53554) gsm-mux: Channel #4 is open
>> I (54514) simcom: State: Enter NetStart state
>> I (54514) gsm-nmea: Startup
>> *I (62414) events: Signal(system.modem.gotgps)*
>> OVMS > metrics list utc
>> m.time.utc 1512915059Sec
>> OVMS > metrics list .p.
>> v.p.altitude 346m
>> v.p.direction 341.2°
>> v.p.gpshdop 1
>> v.p.gpslock yes
>> v.p.gpsmode AA
>> v.p.gpsspeed 0Kph
>> v.p.latitude 51.3023
>> v.p.longitude 7.39013
>> v.p.odometer
>> v.p.satcount 11
>> v.p.speed
>> v.p.trip
>> OVMS > power simcom sleep
>> Power mode of simcom is now sleep
>> I (103104) events: Signal(power.simcom.sleep)
>> I (103514) simcom: State: Enter NetSleep state
>> I (103514) gsm-ppp: Shutting down (soft)...
>> I (103514) gsm-nmea: Shutdown (direct)
>> *I (103514) events: Signal(system.modem.lostgps)*
>> I (154494) events: Signal(power.simcom.on)
>> I (154514) simcom: State: Enter NetStart state
>> I (154514) gsm-nmea: Startup
>> *I (159414) events: Signal(system.modem.gotgps)*
>> I (160544) simcom: PPP Connection is ready to start
>> I (161514) simcom: State: Enter NetMode state
>> I (161514) gsm-ppp: Startup
>> I've changed direction & altitude to float, missed those on the previous rework.
>> I've removed setting "m.time.utc" from the Twizy and Kia modules. On the Roadster, set "enable.gpstime" to "no".
>> I'm getting around 10 satellites all the time with my GSM antenna and our currently very snowy weather, so it seems we don't need active GPS antennas with
>> this module. But I haven't had it on the road yet.
>> Am 10.12.2017 um 09:23 schrieb Michael Balzer:
>>> Toms comment made me test my GSM antenna, lo and behold, it works:
>>> D (298314) gsm-nmea: IncomingLine: $GPGSV,2,1,06,01,,,31,08,26,174,30,14,45,082,37,19,01,323,23*42
>>> D (298314) gsm-nmea: IncomingLine: $GPGSV,2,2,06,22,68,234,25,32,,,35*44
>>> D (298324) gsm-nmea: IncomingLine: $GLGSV,2,1,06,66,19,039,43,82,56,144,38,75,11,007,34,81,07,142,16*6A
>>> D (298334) gsm-nmea: IncomingLine: $GLGSV,2,2,06,67,73,053,46,68,45,213,31*6F
>>> D (298334) gsm-nmea: IncomingLine: $GPGGA,080552.0,5118.139329,N,00723.395918,E,1,02,2.1,316.7,M,47.0,M,,*50
>>> D (298344) gsm-nmea: IncomingLine: $GNGNS,080552.0,5118.139329,N,00723.395918,E,AA,06,2.1,316.7,47.0,,*60
>>> D (298344) gsm-nmea: IncomingLine: $GPVTG,,T,0.0,M,0.0,N,0.0,K,A*0D
>>> D (298354) gsm-nmea: IncomingLine: $GPRMC,080552.0,A,5118.139329,N,00723.395918,E,0.0,,101217,,,A*49
>>> D (298354) gsm-nmea: IncomingLine: $GPGSA,A,2,08,14,,,,,,,,,,,2.3,2.1,0.9*35
>>> D (298364) gsm-nmea: IncomingLine: $GNGSA,A,2,08,14,,,,,,,,,,,2.3,2.1,0.9*2B
>>> D (298364) gsm-nmea: IncomingLine: $GNGSA,A,2,66,67,75,82,,,,,,,,,2.3,2.1,0.9*2F
>>> My GPS antenna is an active one for V2, it seems the current module does not support active antennas.
>>> Actice GPS antennas are the standard choice over here. If the SIM5360 can do without, that will eliminate another energy drain, so is good. Users will need
>>> to know they'll need another antenna.
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20171212/b2a32fbe/attachment-0001.html>
