[Ovmsdev] Fix to esp-idf for adjusting logging levels
Sun Dec 10 10:50:27 HKT 2017
If you have observed that sometimes when you try to adjust logging
levels using the OVMS command "level" that the change is not
effective, the explanation is that the logging code in esp-idf uses a
cache to speed the level lookup but the call to set the level did not
update the cache.  I've fixed that in openvehicles/esp-idf just now.
