[Ovmsdev] Mini-OVMS by Stephan Eipl
Sun Aug 27 00:09:11 HKT 2017
Hi everyone,
Stephan Eipl <stephan.eipl at gmx.de> has created a V2 hardware fork
without GSM modem, just serial port.
He uses a 433 MHz module to access the module, a Bluetooth module (i.e.
HC-05 / HC-06) should do as well.
If you'd like to create a firmware for this hardware, just copy your
build profile and enable the OVMS_FIXED_DIAGMODE compile switch.
If you've got questions about building the hardware or want to order a
PCB, please contact Stephan directly.
Commit:
https://github.com/openvehicles/Open-Vehicle-Monitoring-System/commit/0f4ee3f233177660f9f06adc64ef08c12d6542b7
Files:
https://github.com/openvehicles/Open-Vehicle-Monitoring-System/tree/master/vehicle/Car%20Module/Mini-OVMS
