[Ovmsdev] OVMS v2 Memory/Settings Corruption
Wed Nov 30 05:10:15 HKT 2016
Julien, Pierre,
here's a firmware build with crash debug enabled:
https://dexters-web.de/f/tw-beta/OVMS-Twizy-3.8.2-crashdebug.zip
It excludes the diag mode (serial interface command shell) but is
otherwise complete.
The crash debug logs to the server (when it is/becomes available),
historical record type "*-OVM-DebugCrash". These records expire after 30
days, so you can collect some days.
The crash count and data from the most recent crash will also be shown
by the SMS/text command "DIAG".
The crash records contain a crash count, crash reasons (flags from RCON)
and the last checkpoint seen before the crash.
Am 28.11.2016 um 22:37 schrieb Julien Banchet:
> Sure Michael,
> I've never got around compiling it right, and I'm out of a Windows
> since, wow, I don't even know if grub would boot the partition
> anymore... If you have it under hand (i hope), I'd be happy to give it
> a shot, it would also be the occasion for me next weekend to pull a
> ribbon cable out once and for all (or find a clever way to keep it
> hidden though programmable)
> How does crash recording work ? over Diag ? (PS: 50M/month data if needed)
> Julien
> On Mon, Nov 28, 2016 at 10:16 PM, Michael Balzer <dexter at expeedo.de
> <mailto:dexter at expeedo.de>> wrote:
>     There's no memory management in the module, there's too few RAM
>     available to do dynamic allocations.
>     All buffers are static, the error can be some pointer corruption
>     or missing length check / end of string check.
>     A stack overflow could also be possible, the software stack is 256
>     bytes (1 page). As there's not enough ROM left to support the
>     crash debug framework anymore in the Twizy build, I cannot tell if
>     that happens again.
>     Julien, you could try a reduced build with crash debug recording
>     enabled...
>     Regards,
>     Michael
>     Am 28.11.2016 um 22:00 schrieb Greg D.:
>>     Ah!  That sounds much more likely.
>>     Is there an error (timeout) path that might be freeing the buffer
>>     when it's still in use?
>>     Greg.
>>     Michael Balzer wrote:
>>>     Hi Greg, welcome :)
>>>     Juliens parameter #0 has been overwritten with "Topping o",
>>>     which is part of the charge status message ("Topping off").
>>>     So it's much more likely we've got a buffer corruption bug
>>>     that's triggered by (maybe) bad connectivity situations.
>>>     Regards,
>>>     Michael
>>>     Am 28.11.2016 um 06:38 schrieb Greg D.:
>>>>     Hi all,
>>>>     New here, so this may be totally off the wall.
>>>>     I notice that the first example, with a "5" going to a "k", it
>>>>     may be more easily explained as a bit */shift/* instead of a
>>>>     set of flips.  Is there anywhere in the system where the bytes
>>>>     are clocked serially between devices, where there may be some
>>>>     marginal timing?
>>>>     Just a thought.
>>>>     Greg.
>>>>     Mark Webb-Johnson wrote:
>>>>>     $ perl -e 'printf "%08b\n",ord("5");'
>>>>>     00110101
>>>>>     $ perl -e 'printf "%08b\n",ord("k");'
>>>>>     01101011
>>>>>     $ perl -e 'printf "%08b\n",ord("8");'
>>>>>     00111000
>>>>>     $ perl -e 'printf "%08b\n",ord("Z");'
>>>>>     01011010
>>>>>     Strange. Seems more than a simple bit flip. I haven’t seen this myself, or heard of it much from other users.
>>>>>     Is the Twizy code using EEPROM for anything other than settings storage? I know that there are a very limit number of write cycles into that EEPROM space.
>>>>>     I did some googling, but all I can find is corruption during writing (either power down, or interrupt during write). But, for our case of very very rare EEPROM writes, that shouldn’t be an issue.
>>>>>     Regards, Mark.
>>>>>>     On 25 Nov 2016, at 5:47 AM, Michael Balzer <dexter at expeedo.de> <mailto:dexter at expeedo.de> wrote:
>>>>>>     The EEPROM data loss is a known issue, and I'm afraid there's nothing we can do about that. It seems to be a bug in the PIC18.
>>>>>>     Regards
>>>>>>     Michael
>>>>>>     Am 24.11.2016 um 22:10 schrieb Julien Banchet:
>>>>>>>     Hi all,
>>>>>>>     Thanks to Michaels last message to remind me to ask a question here:
>>>>>>>     Since a few months, maybe a bit more because it happens only once in a while, I have noticed I wasn't receiving the SMS alerts (feature on SMSIP mode) , and sending a "Stats?" only gave me the nasty access denied answer.
>>>>>>>     It turns out, using the application, I noticed that the phone number was getting corrupted (afaik, it's the only setting affected)
>>>>>>>     Normally: "+33651886877 <tel:%2B33651886877>" it became "+336k1886877" or "+33651886Z77" etc... like a solar flare bit flip !_______________________________________________
>>>>>     OvmsDev mailing list
>>>>>     OvmsDev at lists.teslaclub.hk <mailto:OvmsDev at lists.teslaclub.hk>
>>>>>     http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
>>>>>     <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>
>>>     Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>>>     Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
>     _______________________________________________ OvmsDev mailing
>     list OvmsDev at lists.teslaclub.hk
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20161129/73064cca/attachment.htm>
