[Ovmsdev] OVMS v2 Memory/Settings Corruption
Tue Nov 29 02:31:31 HKT 2016
Hi Greg, welcome :)
Juliens parameter #0 has been overwritten with "Topping o", which is
part of the charge status message ("Topping off").
So it's much more likely we've got a buffer corruption bug that's
triggered by (maybe) bad connectivity situations.
Am 28.11.2016 um 06:38 schrieb Greg D.:
> Hi all,
> New here, so this may be totally off the wall.
> I notice that the first example, with a "5" going to a "k", it may be
> more easily explained as a bit */shift/* instead of a set of flips.
> Is there anywhere in the system where the bytes are clocked serially
> between devices, where there may be some marginal timing?
> Just a thought.
> Greg.
> Mark Webb-Johnson wrote:
>> $ perl -e 'printf "%08b\n",ord("5");'
>> 00110101
>> $ perl -e 'printf "%08b\n",ord("k");'
>> 01101011
>> $ perl -e 'printf "%08b\n",ord("8");'
>> 00111000
>> $ perl -e 'printf "%08b\n",ord("Z");'
>> 01011010
>> Strange. Seems more than a simple bit flip. I haven’t seen this myself, or heard of it much from other users.
>> Is the Twizy code using EEPROM for anything other than settings storage? I know that there are a very limit number of write cycles into that EEPROM space.
>> I did some googling, but all I can find is corruption during writing (either power down, or interrupt during write). But, for our case of very very rare EEPROM writes, that shouldn’t be an issue.
>>> On 25 Nov 2016, at 5:47 AM, Michael Balzer <dexter at expeedo.de> wrote:
>>> The EEPROM data loss is a known issue, and I'm afraid there's nothing we can do about that. It seems to be a bug in the PIC18.
>>> Regards
>>> Am 24.11.2016 um 22:10 schrieb Julien Banchet:
>>>> Hi all,
>>>> Thanks to Michaels last message to remind me to ask a question here:
>>>> Since a few months, maybe a bit more because it happens only once in a while, I have noticed I wasn't receiving the SMS alerts (feature on SMSIP mode) , and sending a "Stats?" only gave me the nasty access denied answer.
>>>> It turns out, using the application, I noticed that the phone number was getting corrupted (afaik, it's the only setting affected)
>>>> Normally: "+33651886877" it became "+336k1886877" or "+33651886Z77" etc... like a solar flare bit flip !_______________________________________________
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20161128/27dd2872/attachment.htm>
