[Ovmsdev] Storing Calibration Data
Sat May 7 01:30:49 HKT 2016
Tom,
if you want to store data that cannot be changed directly by the user,
consider using a memory structure and base64 or binary storage in some
parameter slot(s). That gives you 32 byte storage space per parameter
slot, and you can combine multiple parameters if you need more.
Have a look at the Twizy code: parameters 16..21 are marked as binary
and exluded from direct manipulation. They contain struct
twizy_cfg_profile data and can only be changed indirectly through a
specific command extension.
Am 03.05.2016 um 18:13 schrieb Tom Saxton:
> As for configuration, I think there's real value in having a pack energy number, like rated miles, that isn't configurable so it can be compared between owners. If the parameters change, I think it should be based on model configuration (which I'm hoping can be determined from the CAN bus), and not from owner configuration.
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20160506/ca24ca17/attachment-0002.vcf>
