[Ovmsdev] v2.8.5
Sun Mar 27 21:19:04 HKT 2016
Happy to merge when you are ready. Just send through a pull request. It should probably end up in the experimental build, unless you feel it is ready enough for prime-time production.
> On 27 Mar 2016, at 3:33 PM, Geir Øyvind Vælidalo <geir at validalo.net> wrote:
> You have to get it from my repository then. I've been too busy with other things lately. I need to finish some code before I check in into my repository and finally create a pull request. I will try to get some work done as soon as I can :-)
> Best regards,
> Geir
> Sendt fra min iPhone
> Den 26. mar. 2016 kl. 20.37 skrev Robert Cotran <robert at cotran.ca <mailto:robert at cotran.ca>>:
>> OK so I should be compiling it myself then yes?
>> On 3/26/2016 4:07 AM, Michael Balzer wrote:
>>> Robert,
>>> no. The master repository still only has the outdated V0.2 Kia Soul module, that's not included in a build configuration by default.
>>> Am 26.03.2016 um 00:56 schrieb Robert Cotran:
>>>> Hi guys,
>>>> This might be a real noob question, but the 2.8.5 firmware has 4 versions for the V2 hardware:
>>>> - experimental
>>>> - production
>>>> - RT production
>>>> - TR production
>>>> Would the Kia Soul EV code be part of the "production" version?
>>>> Thanks!
>>>> Robert
>>>> On 3/14/2016 7:01 AM, Mark Webb-Johnson wrote:
>>>>> OK, everything looks good to go and I am going to give manufacturing go-ahead for a batch using SIM808 modules tonight.
>>>>> The v2.8.5 firmware is required for SIM808 support, and I’ve built binaries of those ready for release.
>>>>> Please play with this, and let us know if you find any issues.
>>>>> Regards, Mark.
>>>>> 2016-03-14 2.8.5 Firmware 2.8.5 SIM808 GSM/GPS module support
>>>>> # Fix for Twizy build w/o BATTMON
>>>>> # Twizy: ideal range calculated with temperature influence approximation
>>>>> # Twizy: Battery capacity estimation
>>>>> # Twizy: Charge start restarts SOC window (to get most recent BMS SOC)
>>>>> # Twizy: Charge interruption no longer restarts power sums & SOC window
>>>>> # Added vehicle_version to net msg "F"
>>>>> # New vehicle: Kia Soul EV, initial version 0.1 (alpha/untested)
>>>>> # Kia Soul: VIN, car status, doors & charging status, SOC, estimated range, speed
>>>>> # Framework: OBDII polling support for modes 02, 10 & 21
>>>>> # Kia Soul: DEBUG diag output fixed for SMS size limit
>>>>> # Kia Soul: ISR optimization - OBD diag data init & length debugging
>>>>> # Kia Soul: Buffer overflow protection for OBDII multi frame polls
>>>>> # Kia Soul: Init CAN RX filter 1 to avoid noise triggers
>>>>> # Twizy: optional current limit modification
>>>>> # Added compiler switch OVMS_NO_CRASHDEBUG
>>>>> # Twizy V3.7.0: - CFG POWER: max current control, higher torque & power levels
>>>>> # Framework v2.8.2: DIAG mode: support backspace & ctrl-a / ctrl-c (= abort/clear)
>>>>> # Framework v2.8.2: DIAG mode perl clients added
>>>>> # Framework v2.8.2: DIAG mode documentation extended
>>>>> # Add hints on 0x100/0x96 and 0x400/0x01
>>>>> # Framework: Fixed base64decode(), removed bug workarounds
>>>>> # Framework: base64encode(): return pointer to end of base64 string
>>>>> # Framework: New net_assert_caller(): check caller, fallback to REGPHONE
>>>>> # Framework: net_put RAM redirection now uses net_buf[]
>>>>> # Framework: Code cleanup, size and stack depth optimization
>>>>> # Framework: Fix: stack overflow/underflow flags cleared after crash
>>>>> # Framework: Perl diagmode clients: missing license info added
>>>>> # Twizy: Flux map optimization
>>>>> # Twizy: Fix: "CA?" outputs ETR SOC if ETR range is zero
>>>>> # Twizy: CAN control bits to disable emergency reset, kickdown & autopower
>>>>> # Twizy: Flux & saturation maps added to documentation
>>>>> # Twizy: Updated SDO list & limits
>>>>> # MPLABX 3.1x support, and OVMS_BUILDCONFIG to show selected build config in version strings
>>>>> # Add pics and docs on Tesla Model S new style DIAG connector seen in late 2015 cars onwards
>>>>> # Re-work GPS initialisation for SIM808
>>>>> # Use AT+CGPSRST=0 for cold start of GPS
>>>>> # Fix SMS VERSION command
>>>>> OvmsDev mailing list
>>>>> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20160327/13734551/attachment-0001.html>
