[Ovmsdev] v2.8.5
Geir Øyvind Vælidalo
geir at validalo.net
Sun Mar 27 15:33:21 HKT 2016
You have to get it from my repository then. I've been too busy with other things lately. I need to finish some code before I check in into my repository and finally create a pull request. I will try to get some work done as soon as I can :-)
Best regards,
Geir
Sendt fra min iPhone
> Den 26. mar. 2016 kl. 20.37 skrev Robert Cotran <robert at cotran.ca>:
> OK so I should be compiling it myself then yes?
>> On 3/26/2016 4:07 AM, Michael Balzer wrote:
>> Robert,
>> no. The master repository still only has the outdated V0.2 Kia Soul module, that's not included in a build configuration by default.
>>> Am 26.03.2016 um 00:56 schrieb Robert Cotran:
>>> Hi guys,
>>> This might be a real noob question, but the 2.8.5 firmware has 4 versions for the V2 hardware:
>>> - experimental
>>> - production
>>> - RT production
>>> - TR production
>>> Would the Kia Soul EV code be part of the "production" version?
>>> Thanks!
>>> Robert
>>>> On 3/14/2016 7:01 AM, Mark Webb-Johnson wrote:
>>>> OK, everything looks good to go and I am going to give manufacturing go-ahead for a batch using SIM808 modules tonight.
>>>> The v2.8.5 firmware is required for SIM808 support, and I’ve built binaries of those ready for release.
>>>> Please play with this, and let us know if you find any issues.
>>>> Regards, Mark.
>>>> 2016-03-14 2.8.5 Firmware 2.8.5 SIM808 GSM/GPS module support
>>>> # Fix for Twizy build w/o BATTMON
>>>> # Twizy: ideal range calculated with temperature influence approximation
>>>> # Twizy: Battery capacity estimation
>>>> # Twizy: Charge start restarts SOC window (to get most recent BMS SOC)
>>>> # Twizy: Charge interruption no longer restarts power sums & SOC window
>>>> # Added vehicle_version to net msg "F"
>>>> # New vehicle: Kia Soul EV, initial version 0.1 (alpha/untested)
>>>> # Kia Soul: VIN, car status, doors & charging status, SOC, estimated range, speed
>>>> # Framework: OBDII polling support for modes 02, 10 & 21
>>>> # Kia Soul: DEBUG diag output fixed for SMS size limit
>>>> # Kia Soul: ISR optimization - OBD diag data init & length debugging
>>>> # Kia Soul: Buffer overflow protection for OBDII multi frame polls
>>>> # Kia Soul: Init CAN RX filter 1 to avoid noise triggers
>>>> # Twizy: optional current limit modification
>>>> # Added compiler switch OVMS_NO_CRASHDEBUG
>>>> # Twizy V3.7.0: - CFG POWER: max current control, higher torque & power levels
>>>> # Framework v2.8.2: DIAG mode: support backspace & ctrl-a / ctrl-c (= abort/clear)
>>>> # Framework v2.8.2: DIAG mode perl clients added
>>>> # Framework v2.8.2: DIAG mode documentation extended
>>>> # Add hints on 0x100/0x96 and 0x400/0x01
>>>> # Framework: Fixed base64decode(), removed bug workarounds
>>>> # Framework: base64encode(): return pointer to end of base64 string
>>>> # Framework: New net_assert_caller(): check caller, fallback to REGPHONE
>>>> # Framework: net_put RAM redirection now uses net_buf[]
>>>> # Framework: Code cleanup, size and stack depth optimization
>>>> # Framework: Fix: stack overflow/underflow flags cleared after crash
>>>> # Framework: Perl diagmode clients: missing license info added
>>>> # Twizy: Flux map optimization
>>>> # Twizy: Fix: "CA?" outputs ETR SOC if ETR range is zero
>>>> # Twizy: CAN control bits to disable emergency reset, kickdown & autopower
>>>> # Twizy: Flux & saturation maps added to documentation
>>>> # Twizy: Updated SDO list & limits
>>>> # MPLABX 3.1x support, and OVMS_BUILDCONFIG to show selected build config in version strings
>>>> # Add pics and docs on Tesla Model S new style DIAG connector seen in late 2015 cars onwards
>>>> # Re-work GPS initialisation for SIM808
>>>> # Use AT+CGPSRST=0 for cold start of GPS
>>>> # Fix SMS VERSION command
>>>> OvmsDev mailing list
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20160327/a7244916/attachment.html>
