[Ovmsdev] Activating a sleeping Gen 1 Leaf
Collin Kidder collink at kkmfg.com
Sat Mar 12 21:16:41 HKT 2016
The Gen2 does wake up based on a CAN message. I have captures that
show that message being the very first thing over the wire and then
the car wakes up and a ton of messages begin to flow. But, I haven't
tried directly injecting that message to see if I can wake the car up
via the message. It is, however, supposed to work that way. I'll give
it a try when I get a chance.
I actually have both a 2012 and 2013 Leaf so I can do tests for
differences. I'll get a capture from both and compare to see if there
is a good way to distinguish the two over CAN. The CAN data decoded on
mynissanleaf shows things that only exist in one or the other so it
should be very possible to figure out which one you're in.
On Wed, Mar 9, 2016 at 4:35 AM, Tom Parker <tom at carrott.org> wrote:
> Quick update,
> I contorted myself into the driver's foot well of my right hand drive
> Japanese domestic manufacture 2012 gen 1 Leaf and unplugged the TCU. I can
> confirm that connecting pin 1 (battery +ve) to pin 11 (EV System Activation
> Request) causes a beep from the front of the car and a few relay clicks. I
> didn't try to activate climate control to confirm that it works, I'll try
> that later this week and if it does, hook it up to the OVMS. Splice into the
> loom in the cramped conditions under the dashboard won't be fun. I wouldn't
> be totally surprised if the TCU does the charge timer wakeup, so preserving
> the existing circuit is a good idea.
> http://www.mynissanleaf.com/viewtopic.php?p=438109#p438109 says the Gen 2
> Leaf doesn't need this circuit, and the same source describes CAN message to
> do the wakeup. If anyone wants to test that I can add that message to see if
> it works.
> Has anyone seen a message on the EV CAN Bus that would distinguish a Gen 1
> from a Gen 2?
