[Ovmsdev] Possible Manufactoring fault last Batch
Frank Demes frank.demes at gmx.de
Sat Jan 9 04:20:06 HKT 2016
Hi Mark.
The third module arrived today.
Besides some poor soldering on the GPRS Switch everything else looked fine.
My buddys module was also ok.
What about your module Jeromé?
Could you figure out why you had problems reading on the CAN-Bus?
Regards
Frank
> Am 21.12.2015 um 09:46 schrieb Frank Demes <frank.demes at gmx.de>:
> Hi Mark,
> the module worked „fine" at first.
> But I got intermittent failures to write some parameters to the Sevcon.
> That was in the Summer.
> Now with temperatures dropping the module stopped working altogether.
> A buddy of mine got his spare OVMS the same as I did.
> Also I ordered a OVMS last week for another friend of mine.
> I will check both and get back to you on this.
> Regards
> Frank
>> Am 21.12.2015 um 09:11 schrieb Mark Webb-Johnson <mark at webb-johnson.net>:
>> I’m travelling at the moment, but more than 100 of that batch have already been shipped and I haven’t heard of this elsewhere. Maybe just that one module? Or have you seen it on others as well?
>>> On 21 Dec 2015, at 7:28 AM, Frank Demes <frank.demes at gmx.de> wrote:
>>> <image1.PNG>
>>> The stencil seems to be defect so Vdd is missing some paste.
>>> Gruß
>>> Frank
>>>> Am 21.12.2015 um 00:23 schrieb Frank Demes <frank.demes at gmx.de>:
>>>> Hi Jérôme,
>>>> could you check your OVMS for some missing soldering on the CAN chip?
>>>> Gruß
>>>> Frank
>>>>> Am 06.12.2015 um 23:35 schrieb Jérôme Nicolle <jerome at ceriz.fr>:
>>>>> Le 06/12/2015 23:19, Michael Balzer a écrit :
>>>>>> you need to switch on the Twizy to read
>>>>>> registers.
>>>>> Just tried aboard my twizy, in INIT an ON state, couldn't get any reading.
>>>>> Jérôme Nicolle
>>>>> 06 19 31 27 14
>>>>> OvmsDev mailing list
