[Ovmsdev] OVMS v2 Memory/Settings Corruption
Pierre Uhl
pi.uhl at bluewin.ch
Mon Dec 12 17:11:44 HKT 2016
Sorry! Did not had time to flash. Will do it this week.
Pierre
Von: ovmsdev-bounces at lists.teslaclub.hk
[mailto:ovmsdev-bounces at lists.teslaclub.hk] Im Auftrag von Michael Balzer
Gesendet: Sonntag, 11. Dezember 2016 08:58
An: ovmsdev at lists.teslaclub.hk
Betreff: Re: [Ovmsdev] OVMS v2 Memory/Settings Corruption
Got the buffer overrun effect yesterday with the new release.
As I now...
- Keep volatile features over reset
...it now also shows up with random data in features 0-7. Annoying.
Julien, Pierre, any crash debug data collected yet?
Am 29.11.2016 um 22:13 schrieb Julien Banchet:
Thank you Michael,
Will flash it this weekend!
MfG,
JaXX./.
On Tue, Nov 29, 2016 at 10:10 PM, Michael Balzer <dexter at expeedo.de
<mailto:dexter at expeedo.de> > wrote:
Julien, Pierre,
here's a firmware build with crash debug enabled:
https://dexters-web.de/f/tw-beta/OVMS-Twizy-3.8.2-crashdebug.zip
It excludes the diag mode (serial interface command shell) but is otherwise
complete.
The crash debug logs to the server (when it is/becomes available),
historical record type "*-OVM-DebugCrash". These records expire after 30
days, so you can collect some days.
The crash count and data from the most recent crash will also be shown by
the SMS/text command "DIAG".
The crash records contain a crash count, crash reasons (flags from RCON) and
the last checkpoint seen before the crash.
Am 28.11.2016 um 22:37 schrieb Julien Banchet:
Sure Michael,
I've never got around compiling it right, and I'm out of a Windows since,
wow, I don't even know if grub would boot the partition anymore... If you
have it under hand (i hope), I'd be happy to give it a shot, it would also
be the occasion for me next weekend to pull a ribbon cable out once and for
all (or find a clever way to keep it hidden though programmable)
How does crash recording work ? over Diag ? (PS: 50M/month data if needed)
Julien
On Mon, Nov 28, 2016 at 10:16 PM, Michael Balzer <dexter at expeedo.de
There's no memory management in the module, there's too few RAM available to
do dynamic allocations.
All buffers are static, the error can be some pointer corruption or missing
length check / end of string check.
A stack overflow could also be possible, the software stack is 256 bytes (1
page). As there's not enough ROM left to support the crash debug framework
anymore in the Twizy build, I cannot tell if that happens again.
Julien, you could try a reduced build with crash debug recording enabled...
Am 28.11.2016 um 22:00 schrieb Greg D.:
Ah! That sounds much more likely.
Is there an error (timeout) path that might be freeing the buffer when it's
still in use?
Greg.
Michael Balzer wrote:
Hi Greg, welcome :)
Juliens parameter #0 has been overwritten with "Topping o", which is part of
the charge status message ("Topping off").
So it's much more likely we've got a buffer corruption bug that's triggered
by (maybe) bad connectivity situations.
Am 28.11.2016 um 06:38 schrieb Greg D.:
Hi all,
New here, so this may be totally off the wall.
I notice that the first example, with a "5" going to a "k", it may be more
easily explained as a bit shift instead of a set of flips. Is there
anywhere in the system where the bytes are clocked serially between devices,
where there may be some marginal timing?
Just a thought.
Greg.
Mark Webb-Johnson wrote:
$ perl -e 'printf "%08b\n",ord("5");'
00110101
$ perl -e 'printf "%08b\n",ord("k");'
01101011
$ perl -e 'printf "%08b\n",ord("8");'
00111000
$ perl -e 'printf "%08b\n",ord("Z");'
01011010
Strange. Seems more than a simple bit flip. I haven't seen this myself, or
heard of it much from other users.
Is the Twizy code using EEPROM for anything other than settings storage? I
know that there are a very limit number of write cycles into that EEPROM
space.
I did some googling, but all I can find is corruption during writing (either
power down, or interrupt during write). But, for our case of very very rare
EEPROM writes, that shouldn't be an issue.
On 25 Nov 2016, at 5:47 AM, Michael Balzer <mailto:dexter at expeedo.de>
<dexter at expeedo.de> wrote:
The EEPROM data loss is a known issue, and I'm afraid there's nothing we can
do about that. It seems to be a bug in the PIC18.
Regards
Am 24.11.2016 um 22:10 schrieb Julien Banchet:
Hi all,
Thanks to Michaels last message to remind me to ask a question here:
Since a few months, maybe a bit more because it happens only once in a
while, I have noticed I wasn't receiving the SMS alerts (feature on SMSIP
mode) , and sending a "Stats?" only gave me the nasty access denied answer.
It turns out, using the application, I noticed that the phone number was
getting corrupted (afaik, it's the only setting affected)
Normally: "+33651886877 <tel:%2B33651886877> " it became "+336k1886877" or
"+33651886Z77" etc... like a solar flare bit flip
!_______________________________________________
OvmsDev mailing list
OvmsDev at lists.teslaclub.hk <mailto:OvmsDev at lists.teslaclub.hk>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20161212/0672c5b5/attachment.htm>
