[Ovmsdev] OVMS update
mark at openvehicles.com
Wed Dec 14 20:38:32 HKT 2016
> - Do you forsee a data envelope to have on the mobile provider ? (payload * rythme might go up) I suppose most of the things can(/will) be configurable on the backend/provisionning side ("discard this"/"limit these to once an hour”…)
We are hoping to be able to control reporting with better granularity. Data usage will probably have to go up (MQQT is not as efficient as our proprietary protocol), but we can offset that by smarter usage of the cellular network as well as use of wifi where available.
> - Will the backend be rewritten? I suppose it will have to, as this is nothing alike before... What language will it be based on? Honestly, I have loved Perl in the past, and even though I'm far from being Python fluent, the latter might be a better pick in terms of adoption.
We are planning on using a standard MQTT backend. Currently working with mosquito. There are some ancillary scripts, but not too many.
> On 14 Dec 2016, at 4:47 PM, Julien Banchet <jaxx at jaxx.org> wrote:
> Hi Mark,
> Many Thanks for the update, I honestly can't wait as every single point of features are great!
> Just a couple of questions:
> - Do you forsee a data envelope to have on the mobile provider ? (payload * rythme might go up) I suppose most of the things can(/will) be configurable on the backend/provisionning side ("discard this"/"limit these to once an hour"...)
> Again, Thanks !
> JaXX./.
> On Wed, Dec 14, 2016 at 2:00 AM, Mark Webb-Johnson <mark at openvehicles.com <mailto:mark at openvehicles.com>> wrote:
> A short update on OVMS.
> We are working hard on OVMS v3. The development environment for the microcontroller we chose for v3 has finally stabilised to a point where we can rely on it. There will be a new revision of hardware silicon around the end of 2017Q1 and we'll most likely try to time the first production releases of OVMS v3 to use that as soon as it is available. But, the good news is that we have the production development environments available now, and the CAN driver (although early beta) is working well. All the components are finally in place and usable. This has caused us delays in our plans, but we are confident that our choice of microcontroller was the right one. This will give us a great platform for the future and most importantly allow us to keep costs down without being constrained by RAM/Flash memory storage (as was the case for the v2 PIC18 platform). Bluetooth and Wifi support are a bonus. Work on the firmware for OVMS v3 is ongoing, and we're hoping to release this to the open source team any day now. Some highlights of the coming features for OVMS v3 include:
> Use of the industry standard MQTT protocol, for easier third party integration (in particular to IOT and home automation systems)
> Event driven model for scripting events in the car (such as geofencing, homelink, charge settings, etc)
> 3G
> Wifi
> Bluetooth
> SD-CARD support
> Reduced power consumption, and low-power sleep modes
> Dramatically more RAM and FLASH memory, to overcome limits of PIC18 architecture used by OVMS v2
> Firmware updates via SD-CARD and USB, without any special programming tools
> Over-The-Air (OTA) firmware updates via wifi and/or 3G
> Expansion slot and port for extra functionality
> In the meantime, we continue to support OVMS v2. The hardware is still available on fasttech site, but we are over half way through what we think will be the very last batch.
> In other news, we have partnered with hologram.io <http://hologram.io/> to provide a cellular network for OVMS users (both v2 and v3). Early feedback from our users has been fantastic, and this is now running in a bunch of OVMS cars. Use of this is entirely optional, and the cost-effectiveness will depend on where you are in the world and what other cellular options you have. We're not forcing you to use Hologram; just making it easy for you to choose them if you want. OVMS v3 will come with hologram.io <http://hologram.io/> SIMs included as standard (but easily replaced if you choose not to use it). For OVMS v2 users in USA, with the imminent shutdown of the AT&T 2G network, we recommend Hologram.IO now. You can get SIMs from Hologram directly at https://hologram.io/store/ <https://hologram.io/store/>, and Tom has penned an excellent write-up of how to switch to Hologram at https://www.idleloop.com/tesla/ovms/hologram.php <https://www.idleloop.com/tesla/ovms/hologram.php>.
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20161214/68f7c3ad/attachment-0001.html>
