[Ovmsdev] Twizy release 3.8.2
Sat Dec 10 02:06:01 HKT 2016
https://dexters-web.de/ovms-twizy-3.8.2-text_79.en.htm
OVMS Twizy Firmware V3.8.2
Firmware:
http://dexters-web.de/f/tw/OVMS-Twizy-3.8.2.zip
Framework V2.9.2:
- Keep volatile features over reset
- Added speed & trip length to location update (msg L)
- Added b4 + substate to JSON API
- Fixed spelling of 'charge_etr_range' in JSON API
Twizy 3.8.2:
- Fill framework car_chargelimit from feature #7
- Added charge power to MSG CMDs #203,204 (Query/Set ChargeAlerts)
- Skip feature init on CPU reset
- Inhibit CPU reset during charging with charge power override
- New: charge auto stop control (feature #6 / car_chargemode)
- Added charge control to commands CA & #203,204
- Tightened SDO bus timing
- Minor code size optimizations
Charge stop mode is controlled via feature 6 or combined with limits and
power level using the reworked "CA" & #203,204 commands.
For example, to enable automatic charge stop on reaching a sufficient
charge limit, issue:
    FEATURE 6 1
or
    CA S
To set charge to stop at 80% SOC and use power level 3 = 1 kW, issue:
    CA 80% S L3
The Android App charge limit UI has been updated accordingly in V3.12.1.
See documentation for more details.
Source:
https://github.com/openvehicles/Open-Vehicle-Monitoring-System/
