[Ovmsdev] net.c SOC alert obsolete?
Wed Apr 20 13:00:26 HKT 2016
Yeah, the roadster owners really need it there and it deliberately overrides the normal systems and sends by SMS. I would be reluctant to remove it.
> On 19 Apr 2016, at 5:23 AM, Michael Balzer <dexter at expeedo.de> wrote:
> Tom,
> so the roadster doesn't cut off the battery to avoid deep discharging?
> Sounds like a bad BMS bug...
> Ok, that's a very good reason why this kind of alert should be sent out
> on all channels available.
> Thanks & regards,
> Am 18.04.2016 um 20:56 schrieb Tom Saxton:
>> Personally, I like having the second backup warning that doesn’t depend on a setting being right. It’s a big deal if our Roadster gets down to 5% accidentally.
>>   Tom
>> On 4/18/16, 8:35 AM, "Michael Balzer" <ovmsdev-bounces at lists.teslaclub.hk on behalf of dexter at expeedo.de> wrote:
>>> Hi everyone,
>>> we've currently two low SOC alerts in the framework, one is the
>>> configurable (feature #9) min SOC alert in vehicle_ticker(), the other
>>> is the OVMS_SOCALERT code in net_state_ticker600().
>>> The latter is fixed to 5% and does not respect user channel &
>>> notification configuration. Is there still a use case for this or is it
>>> obsolete?
