[Ovmsdev] OvmsDev Digest, Vol 51, Issue 1
Wed Apr 13 08:59:11 HKT 2016
We haven’t changed the certificate yet, so please keep using www.openvehicles.com <http://www.openvehicles.com/> for the HTTP API.
> On 13 Apr 2016, at 12:09 AM, John Link <jjlink.net at gmail.com> wrote:
> Hello, Since the DNS change I can't seem to get curl to work any more to retrieve data from the server. this is the error message I am getting:
> curl: (51) SSL: certificate subject name (www.openvehicles.com <http://www.openvehicles.com/>) does not match target host name 'api.openvehicles.com <http://api.openvehicles.com/>'
> Does your ssl cert need to be updated for the new host name?
> Thanks
> On Mon, Apr 4, 2016 at 9:00 PM, <ovmsdev-request at lists.teslaclub.hk <mailto:ovmsdev-request at lists.teslaclub.hk>> wrote:
> Send OvmsDev mailing list submissions to
> ovmsdev at lists.teslaclub.hk <mailto:ovmsdev at lists.teslaclub.hk>
> To subscribe or unsubscribe via the World Wide Web, visit
> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> ovmsdev-owner at lists.teslaclub.hk <mailto:ovmsdev-owner at lists.teslaclub.hk>
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of OvmsDev digest..."
> Today's Topics:
> 1. api.openvehicles.com <http://api.openvehicles.com/> (Mark Webb-Johnson)
> Message: 1
> Date: Tue, 5 Apr 2016 11:51:01 +0800
> From: Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>>
> Subject: [Ovmsdev] api.openvehicles.com <http://api.openvehicles.com/>
> To: OVMS Developers <OvmsDev at lists.teslaclub.hk <mailto:OvmsDev at lists.teslaclub.hk>>
> Message-ID: <FB00A027-1D7A-4859-95F9-EB1C0212536F at webb-johnson.net <mailto:FB00A027-1D7A-4859-95F9-EB1C0212536F at webb-johnson.net>>
> Content-Type: text/plain; charset="utf-8"
> I?ll be moving all users of either IP 54.197.255.127 or DNS name tmc.openvehicles.com <http://tmc.openvehicles.com/> <http://tmc.openvehicles.com/ <http://tmc.openvehicles.com/>> to DNS name api.openvehicles.com <http://api.openvehicles.com/> <http://api.openvehicles.com/ <http://api.openvehicles.com/>> later today. Also switching DNS record for tmc.openvehicles.com <http://tmc.openvehicles.com/> <http://tmc.openvehicles.com/ <http://tmc.openvehicles.com/>> to be api.openvehicles.com <http://api.openvehicles.com/> <http://api.openvehicles.com/ <http://api.openvehicles.com/>>. This will be done by the server at 54.197.255.127 issuing an OVMS protocol message to change parameter PARAM_SERVERIP (#4) to ?api.openvehicles.com <http://api.openvehicles.com/>?.
> In general, going forward, using DNS name api.openvehicles.com <http://api.openvehicles.com/> <http://api.openvehicles.com/ <http://api.openvehicles.com/>>, on both the car module and Apps, will be the recommended approach. That will allow us to do server maintenance and migrations without requiring everyone to change their settings.
> If you would like to test this before the actual event later today, then just change your car module parameter #4 (SERVERIP) to api.openvehicles.com <http://api.openvehicles.com/> <http://api.openvehicles.com/ <http://api.openvehicles.com/>> now.
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20160405/36dc7d13/attachment-0001.html <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20160405/36dc7d13/attachment-0001.html>>
> End of OvmsDev Digest, Vol 51, Issue 1
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20160413/10767adf/attachment.html>
