[Ovmsdev] OvmsDev Digest, Vol 51, Issue 1
John Link
jjlink.net at gmail.com
Wed Apr 13 00:09:39 HKT 2016
Hello, Since the DNS change I can't seem to get curl to work any more to
retrieve data from the server. this is the error message I am getting:
curl: (51) SSL: certificate subject name (www.openvehicles.com) does not
match target host name 'api.openvehicles.com'
Does your ssl cert need to be updated for the new host name?
Thanks
On Mon, Apr 4, 2016 at 9:00 PM, <ovmsdev-request at lists.teslaclub.hk> wrote:
> Send OvmsDev mailing list submissions to
> ovmsdev at lists.teslaclub.hk
> To subscribe or unsubscribe via the World Wide Web, visit
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> ovmsdev-owner at lists.teslaclub.hk
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of OvmsDev digest..."
> Today's Topics:
> 1. api.openvehicles.com (Mark Webb-Johnson)
> Message: 1
> Date: Tue, 5 Apr 2016 11:51:01 +0800
> Subject: [Ovmsdev] api.openvehicles.com
> To: OVMS Developers <OvmsDev at lists.teslaclub.hk>
> Message-ID: <FB00A027-1D7A-4859-95F9-EB1C0212536F at webb-johnson.net>
> Content-Type: text/plain; charset="utf-8"
> I?ll be moving all users of either IP 54.197.255.127 or DNS name
> tmc.openvehicles.com <http://tmc.openvehicles.com/> to DNS name
> api.openvehicles.com <http://api.openvehicles.com/> later today. Also
> switching DNS record for tmc.openvehicles.com <
> http://tmc.openvehicles.com/> to be api.openvehicles.com <
> http://api.openvehicles.com/>. This will be done by the server at
> 54.197.255.127 issuing an OVMS protocol message to change parameter
> PARAM_SERVERIP (#4) to ?api.openvehicles.com?.
> In general, going forward, using DNS name api.openvehicles.com <
> http://api.openvehicles.com/>, on both the car module and Apps, will be
> the recommended approach. That will allow us to do server maintenance and
> migrations without requiring everyone to change their settings.
> If you would like to test this before the actual event later today, then
> just change your car module parameter #4 (SERVERIP) to
> api.openvehicles.com <http://api.openvehicles.com/> now.
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20160405/36dc7d13/attachment-0001.html
> End of OvmsDev Digest, Vol 51, Issue 1
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20160412/3e1ac3a3/attachment.html>
