[Ovmsdev] Kia Soul Pull request
Mon Apr 11 09:25:49 HKT 2016
I tried to pull this in, but it seems several system makefiles have been changed and that is conflicting for me.
I’ll try to pull in the {*.h,*.c} changes and include Kia Soul in the Experimental configuration (as there is room there).
> On 7 Apr 2016, at 10:04 PM, Geir Øyvind Vælidalo <geir at validalo.net> wrote:
> Hi guys,
> I’ve sent a pull request for the newest Kia Soul-version. I want to do more, but at the moment my time is insufficient, so I thought it was as good time as any to get mye code into the master repository. Maybe someone else can do some good.
> There are definitively bugs there, but I’ve been running on this version for a few months, so I haven’t broken anything important, I think :-D
> Also, I hope that I haven’t made to much mess in the project! I’m sort of proud of what I have managed even though this have been a trial and error-kind of project on my part ;-)
> I’ve done some playing around with the iOS-app too. Fixed some issues with the newer Xcode/iOS-version and added some things I thought was interesting to have, mainly because I needed to play around to try to understand Xcode and the app-itself. I’m not sure if I should send a pull request for that code, as the iOS-version will differ more from the android-version.
> I’ve added this:
> 	- aux-battery voltage in the car-screen
> 	- When charging, it displays:
> 		- minutes remaining
> 		- minutes charged
> 		- kWh charged
> 		- Charging speed in kW.
> What do you think? Should I check in and send a pull request for that too?
> Best regards,
> Geir
