[Ovmsdev] api.openvehicles.com
Tue Apr 5 11:51:01 HKT 2016
I’ll be moving all users of either IP 54.197.255.127 or DNS name tmc.openvehicles.com <http://tmc.openvehicles.com/> to DNS name api.openvehicles.com <http://api.openvehicles.com/> later today. Also switching DNS record for tmc.openvehicles.com <http://tmc.openvehicles.com/> to be api.openvehicles.com <http://api.openvehicles.com/>. This will be done by the server at 54.197.255.127 issuing an OVMS protocol message to change parameter PARAM_SERVERIP (#4) to ‘api.openvehicles.com’.
In general, going forward, using DNS name api.openvehicles.com <http://api.openvehicles.com/>, on both the car module and Apps, will be the recommended approach. That will allow us to do server maintenance and migrations without requiring everyone to change their settings.
If you would like to test this before the actual event later today, then just change your car module parameter #4 (SERVERIP) to api.openvehicles.com <http://api.openvehicles.com/> now.
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20160405/36dc7d13/attachment.html>
