[Ovmsdev] Firmware 2.8.1
Karl Erik Asbjørnsen
karl at asbjornsen.org
Fri Sep 25 17:54:44 HKT 2015
Hi. Just tried to set the server ip parameter via the android app to
tmc.openvehicles.com. Did a "Reset OVMS Modules" to be sure, and connection
is fine.
Carrier is Telenor in Norway
Karl Erik
On Fri, Sep 25, 2015 at 4:10 AM, Mark Webb-Johnson <mark at webb-johnson.net>
wrote:
> While I agree about the TTL and possibility of badly configured caching
> servers not honouring it, in the greater scheme of things it is really
> irrelevant.
> This last change of address was urgently made by TMC, not realising it
> would impact us. It is only by blind luck that they hadn’t released the old
> address back to the amazon pool. If that had happened, every user would
> have had to manually sms their cars to make the change.
> Luckily, they hadn’t released the address, so could assign it to another
> VM. I then did a socat on that machine, to forward the traffic to our new
> address. Then, some magic on the ovms_server.pl to reprogram cars
> connecting from the old address to switch to the new one. We’d done a
> similar thing a few years back, so I knew it would work.
> Faced with that, a couple of hours of downtime, due to a DNS switch, is
> not so worrying ;-)
> That said, I don’t see any option on register.com to set the TTL. Seems
> fixed at 4 hours. I’ll check further.
> Regarding the change from server IP to server name, I would be grateful if
> more developers could try it, around the world. Let me know the results
> here. In particular, with the popular carriers in USA and Europe. It would
> be vastly simpler to just tell people to change to use a name, rather than
> messing around with google DNS servers.
> On 25 Sep, 2015, at 12:17 am, HONDA S-2000 <s2000 at audiobanshee.com> wrote:
> On Sep 24, 2015, at 5:46 AM, Collin Kidder <collink at kkmfg.com> wrote:
> On Thu, Sep 24, 2015 at 5:38 AM, Michael Balzer <dexter at expeedo.de> wrote:
> I just checked the DNS record for tmc.openvehicles.com:
> tmc.openvehicles.com. 14399 IN A 54.197.255.127
> I suggest reducing the TTL to 1 hour before we recommend the change to
> users.
> Keep in mind that much of the internet is ruled by caching name
> servers that will be quite stubborn about having to update their
> records. I seriously doubt that a TTL of 1 hour will be honored by
> much of anything. You're lucky if the ISP name servers bother to check
> for updates more than once or twice a day.
> I'm fairly certain that there are no caching servers that ignore TTL. It
> would thwart emergency services if short TTL values were ignored. My ISP
> has changed my server ip address only once, and they went through the same
> process of shortening the TTL before the scheduled change, then increasing
> it back to normal after the new ip address was activated.
> The catch is that any change does not take effect until the old TTL
> expires. The "14399" above is 4 hours. So, if the TTL were changed to 1
> hour, it would not take effect on all caching servers until 4 hours later.
> At that point, though, all DNS servers would be working with a TTL of 1
> hour. The typical is more like 24 hours, so the 4 hour entry above is
> rather short. If 24 hours were used, then the ISP would need to start the
> process 24 hours early by changing the TTL to 1 hour a whole day in advance
> of the ip address change. But at long as you know the current TTL and plan
> ahead, it's always possible to make a prompt transition.
> Those name servers that only bother to check once or twice a day are doing
> exactly as they're told, and will check every hour if told to do so instead.
> Brian
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20150925/b5b7e867/attachment.html>
