[Ovmsdev] Twizy release 3.6.1
Tue Oct 27 08:47:58 HKT 2015
The Android PUSH notification issue is caused by Google turning off the C2DM push notification system we use. They have obsoleted the service for all users of c2dm.
We are trying to migrate to the replacement GCM (Google Cloud Messaging), but it is not a simple replacement. The server side support needs to be re-written. While the changes in the App should be simple, GCM seems to require newer google frameworks, which break some of the libraries we are using.
We are working on it, but Android PUSH notification not working at the moment.
> On 26 Oct, 2015, at 10:34 pm, Fran Terry <fterry at tesco.net> wrote:
> Hi Micheal,
> Seems to be an issue with this new version, not geting any notifications from OVMS via IP, not tried this via SMS yet. If I send a command via Andoird App, system sends back reply OK.
> Also noticed a possible issue with CFG profile not applying before each trip.
> Currently have feature #14 set to 0, however also tried with 64.
> Any ideas?
> Thanks
> Fran
> On 03/10/2015 17:49, Michael Balzer wrote:
>> Package:
>> http://dexters-web.de/f/tw/OVMS-Twizy-3.6.1.zip <http://dexters-web.de/f/tw/OVMS-Twizy-3.6.1.zip>
>> Changes:
>> see tag "V3.6" in the user guide
>> Framework V2.7.4:
>> - New compiler switches to disable framework functions:
>> OVMS_NO_CHARGECONTROL
>> OVMS_NO_CTP
>> OVMS_NO_SMSTIME
>> OVMS_NO_VEHICLE_ALERTS
>> (all need to be set for Twizy build)
>> - Potential buffer overflow fix in net_msg_forward_sms()
>> - Fix stp_l2f() for negative values
>> - Fix SMS MSG wrapper for long commands
>> Framework V2.8.1:
>> - Make COPS more lenient
>> - Support GPRS DNS
>> Twizy V3.6.0:
>> - New: All power values now based on real battery power (current * voltage)
>> - Battery current sums + min/max moved to separate fields
>> - STAT command extended by grid energy drain estimation
>> - RT-GPS-Log extended by BMS limits, auto power levels and battery
>> current min/max
>> - RT-PWR-Log extended by battery coulomb counts (Ah)
>> - "RT-PWR-UsageStats" is now "RT-PWR-Stats", fields reordered and units
>> converted
>> (to save space), coulomb count discharge/charge sums added (Ah)
>> - Rework & bug fixes in auto power adjustment
>> - Auto RECUP power adjustment extended by 100% reference power
>> (ATT: CFG RECUP parameters changed!)
>> - New: auto DRIVE power adjustment
>> (ATT: CFG DRIVE parameters changed!)
>> - New: CFG CLEAR = clear SEVCON diagnostic logs
>> - Now using GSM time (NET_FN_CARTIME) for more accurate parking times
>> - New: feature #14 & 64 = send notification on charge starts
>> - Fixed charge time estimation for SOC > 94%
>> - ISR performance optimization
>> - car_SOC no longer rounded to avoid 99.5% == 100%
>> - Trip end odometer saved & used for RT-PWR-Log charge entries
>> - Fixed auto power minprc calculation with default (-1)
>> - Fixed auto power calculations for default minprc values
>> - Changed auto recup level to scale levels configured
>> Twizy V3.6.1:
>> - Fix: battery alert state also remembered for IP notification
>> - Fix: compiling without OVMS_TWIZY_CFG
>> - ideal range calculated with temperature influence approximation
>> - Battery capacity estimation
>> - Charge start restarts SOC window (to get most recent BMS SOC)
>> - Charge interruption no longer restarts power sums & SOC window
>> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20151027/13099c36/attachment.html>
