[Ovmsdev] Need help with CAN-polling.
Mon Nov 16 06:00:17 HKT 2015
Geir,
I did not configure a CAN filter for 0x7D*. Filter 0 is only configured
for 0x7E8 .. 0x7EF.
May be you can use filter 1 for the 7D* range, or open up filter 0 to
accept more.
See vehicle_kiasoul_initialise().
Am 15.11.2015 um 19:53 schrieb Geir Øyvind Vælidalo:
> Hi guys,
> I have a problem with getting the OVMS to fetch TPMS data from my Kia.
> This is what I do to get the data using ELM327 and a “terminal” on my
> iPhone:
> >atcra 7de
> OK
> >21 06
> 7DE 10 22 61 06 00 25 A7 CB
> 7DE 21 00 37 00 00 00 25 3E
> 7DE 22 93 00 37 00 00 00 25
> 7DE 23 9D F5 00 37 00 00 00
> 7DE 24 25 3F 65 00 37 00 00
> It returns the data I need, but when I add this to the poll-list in OVMS:
> { 0x7df, 0x7de, VEHICLE_POLL_TYPE_OBDIIGROUP, 0x06, { 60, 10, 0 } },
> // TMPS
> I get no response :-(
> I’ve tried different module id’s but I don’t quite understand which
> one the ELM uses. I’ve added several other polls without any problems
> to the Kia code, and I’m pretty sure the problem isn’t in the
> poll0-code, as i’ve only added a case 0x7de, and it never seems to
> trigger.
> Any tips or ideas?
> Best regards,
> Geir
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20151115/43693df5/attachment.htm>
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20151115/43693df5/attachment-0002.vcf>
