[Ovmsdev] Open Charge map
Geir Øyvind Vælidalo
geir at validalo.net
Tue Nov 3 04:18:15 HKT 2015
I understand. Then something is wrong with the latest iOS version, I believe. It cant open the getcorereferencedata from OCM, so in the connection-scene I can’t see anything at all.
I tried to open up the security by editing Info.plist file so that the app will "allow arbitrary loads”, but then it fails later on.
This is too heavy material for me to dig into now :-)
Geir
> 2. nov. 2015 kl. 18.28 skrev Michael Balzer <dexter at expeedo.de>:
> Geir,
> the OCM charge plugs config should be available in the car editor.
> The dialog attached to the battery indicator is meant to configure the
> current/next charging session, which is not yet implemented on the Kia
> (and likely will need some changes).
> Am 02.11.2015 um 14:41 schrieb Geir Øyvind Vælidalo:
>> Hi all,
>> I'm having trouble seeing chargers on the map in the iOS-app. When I press
>> the "Filtered Stations ON" I get a message saying that the selected car
>> has no setup of charger type.
>> I guess it is talking about the charger settings I get when I press the
>> large battery indicator, but whatever I choose here, I get unimplemented
>> operation.
>> Is this the correct place to register the charger type?
>> Do you have any pointers for where to start in the code?
>> Best regards,
>> Geir
