[Ovmsdev] Kia Soul EV version 0.2 problems
Robert Cotran
robert at cotran.ca
Thu Nov 5 06:23:39 HKT 2015
I'm up and running!
The power is to the module is now stable, and I went out and got a
Rogers SIM (not a Bell SIM -- attention Canadians, Bell SIMs do NOT
work), and I can talk to the car finally.
PHEW!
I got a data-only plan so SMSes are 15c each, so I really want to figure
out how to get data (GPRS) communications working in an ad hoc way
because I can't rely on text messages -- too expensive. I'll do some
reading about that.
Then I'll start testing out the Kia Soul EV specific functionality.
Woohoo! this is awesome!
Rob
On 11/3/2015 2:48 PM, Robert Cotran wrote:
> OK so I had/have two problems:
> 1) the OVMS board had a bad connection on the ground input, so power
> wasn't getting to the board properly hence the weird flashing lights.
> We fixed that with a more solid ground connection soldered to a couple
> pins.
> 2) the SIM card I'm using does NOT work with the board. I hooked up
> the diag port and it says "NOT INSERTED" for CPIN. With another
> cellular provider's SIM, it did work. So now I have to find a way to
> get this happening. I can only get cheap data with my current
> provider, so I'm going to hunt for an old SIM that might work.
> So things are on pause until I'm able to do that...
> Rob
> On 11/2/2015 8:22 AM, Mark Webb-Johnson wrote:
>> About 200mA would be safest. A bench 12V power supply is fine.
>> Regards, Mark
>>> On 2 Nov 2015, at 9:20 PM, Robert Cotran <robert at cotran.ca> wrote:
>>> Hi all,
>>> I will definitely hook up to the diag port. I do have a USB-serial
>>> cable. Thanks for that suggestion!
>>> Does anyone know if one can power the unit "on a bench" using a 12V
>>> adapter? I read that the OBDII port only gives out a max of 100mA,
>>> is that true? If it is true, a small 12V adapter should be fine...
>>> Thanks!
>>> Rob
>>> On 11/1/2015 9:25 PM, Mark Webb-Johnson wrote:
>>>> The other thing to suggest is if you have a USB-serial cable and a
>>>> laptop, you can plug into the DIAG port at 9600baud, and have a
>>>> look at the messages from the modem. That should tell you exactly
>>>> what is going on. But if you count the blinks, and they go 10 then
>>>> 9 then reset then 10 then 9, it is most likely the SIM connection.
>>>> Regards, Mark.
>>>>> On 2 Nov, 2015, at 4:59 am, Robert Cotran <robert at cotran.ca> wrote:
>>>>> Hi all again,
>>>>> I'm really not having any luck here.
>>>>> I've tried three different SIM cards now, and they all do exactly
>>>>> the same thing. I haven't read anywhere about the red and green
>>>>> lights being on simultaneously and flashing like crazy so I'm
>>>>> really starting to suspect that the hardware is defective. I wish
>>>>> I had another kit lying around.
>>>>> The kit I have is from my friend but it's brand new, it has never
>>>>> been used in a car before.
>>>>> I'm wondering if I should just order another kit to see if the
>>>>> same thing happens.
>>>>> I did have a question. If I simply power the OBDII port on the
>>>>> kit with 12V, should it power up normally? I could test that...
>>>>> Geir, my car is in Canada, so I don't have UVO services
>>>>> unfortunately, hence the reason I'd really like to get this going!
>>>>> I'm on the KIA Soul EV forums, and once I have this working, I'll
>>>>> try to rope in someone in the US who would be willing to monitor
>>>>> their CAN Bus so we can snoop and try to copy the HVAC calls.
>>>>> Rob
>>>>> On 11/1/2015 12:09 PM, Michael Balzer wrote:
>>>>>> Rob,
>>>>>> green 8 + red 4 = SIM lock... I don't know how a phone could use
>>>>>> a locked SIM for data, but just try setting and again removing
>>>>>> the SIM lock with the SIM toolkit.
>>>>>> Some (very few) SIMs just don't work in the OVMS, it's unlikely
>>>>>> you stumbled across two of them.
>>>>>> I once had the effect of a flash process that failed without any
>>>>>> error output, so you also should try re-flashing.
>>>>>> Of course the hardware can be broken too, i.e. bad SIM slot
>>>>>> soldering causing data errors or bad antenna connection. As your
>>>>>> module has been used before (I assume?) that's quite unlikely.
>>>>>> Regards,
>>>>>> Michael
>>>>>> Am 01.11.2015 um 17:40 schrieb Robert Cotran:
>>>>>>> Hi again,
>>>>>>> I tried the SIM card in a cell phone. Worked perfectly, got data
>>>>>>> connection and was able to download data.
>>>>>>> I doubt it's locked, it's brand new. The phone didn't ask me for
>>>>>>> a code.
>>>>>>> I verified the antennas are plugged correctly.
>>>>>>> Can the OVMS kit be defective? Does that happen?
>>>>>>> Could the KIA firmware specifically have caused an issue? Then
>>>>>>> again, Geir has it working no problem.
>>>>>>> Rob
>>>>>>> On 11/1/2015 10:48 AM, Michael Jochum wrote:
>>>>>>>> Hi,
>>>>>>>> have you tried the SIM Card in an Cell Phone? Did this work?
>>>>>>>> Is the Card locked with a Pin code? OVMS can't handle PIN
>>>>>>>> locked cards.
>>>>>>>> Do you connect the Antennas to their right plugs?
>>>>>>>> Bye
>>>>>>>> Michael
>>>>>>>>> Am 01.11.2015 um 16:13 schrieb Robert Cotran <robert at cotran.ca>:
>>>>>>>>> Hi all,
>>>>>>>>> I'm happy to see that it looks like development of the Kia
>>>>>>>>> Soul EV firmware is going to continue, thanks to Micheal and Geir!
>>>>>>>>> I went out and bought a dedicated SIM for the OVMS kit
>>>>>>>>> yesterday and flashed the OVMS with 0.2 of the Kia Soul
>>>>>>>>> firmware and I flashed the EEPROM as well since this is a new
>>>>>>>>> installation and there's nothing on the kit yet.
>>>>>>>>> It's still not working unfortunately. When I plug it into the
>>>>>>>>> car, the red LED comes on for a few seconds, then the red and
>>>>>>>>> green flash a bit, and then they both stay off for about 10-15
>>>>>>>>> seconds, then the green flashes 10 times, then 9 times, then I
>>>>>>>>> think 8 or 9 times, and then the red LED flashes a few times
>>>>>>>>> while the green is flashing, and then then both start to flash
>>>>>>>>> on and off extremely fast, so fast that it looks like they are
>>>>>>>>> both on solid. They stay like this for about 7 or 8 seconds,
>>>>>>>>> and then it starts all over again from the 10, 9 on green.
>>>>>>>>> I've followed the Roadster guide to getting this up and
>>>>>>>>> running, I've cleaned the SIM contacts and I've tried two
>>>>>>>>> different SIM cards, so I'm a bit lost as to what I can try next.
>>>>>>>>> Does anyone have any suggestions?
>>>>>>>>> Thanks!
>>>>>>>>> Rob
>>>>>>>>> On 10/31/2015 5:20 PM, Michael Balzer wrote:
>>>>>>>>>> Welcome Robert :-)
>>>>>>>>>> Basic setup of the Kia firmware is the same as for other
>>>>>>>>>> models. So you can follow the Roadster guide or one of the
>>>>>>>>>> Twizy guides first.
>>>>>>>>>> You wrote to me you got the module from a friend, so you
>>>>>>>>>> should first flash once without preserving EEPROM to get a
>>>>>>>>>> clean config to start with.
>>>>>>>>>> Follow Marks link to the support FAQ if you get stuck in the
>>>>>>>>>> config process. To diag LED flash codes, also take a look at
>>>>>>>>>> the state machine diagram in the main docs folder. If you
>>>>>>>>>> need help, describe exactly (!) which doc you've been
>>>>>>>>>> following and what you have done so far.
>>>>>>>>>> If you're stuck at 10/9... maybe you should first check if
>>>>>>>>>> the SIM card has contact.
>>>>>>>>>> Kia V0.1 only reads some first status messages and obtains
>>>>>>>>>> the VIN if you enable CAN write access (FEATURE 15 1). I've
>>>>>>>>>> currently got one positive and one negative test feedback for
>>>>>>>>>> this version.
>>>>>>>>>> Would be great if you could also check V0.2 -- it's in my
>>>>>>>>>> account on github:
>>>>>>>>>> https://github.com/dexterbg/Open-Vehicle-Monitoring-System
>>>>>>>>>> ...hex:
>>>>>>>>>> http://dexters-web.de/f/kiasoul/OVMS-KiaSoul-0.2.zip
>>>>>>>>>> This _should_ be able to show some first OBD diag data dumps
>>>>>>>>>> (DEBUG 1 / 5)... as I don't have a Kia, I need qualified beta
>>>>>>>>>> test feedback.
>>>>>>>>>> Regards,
>>>>>>>>>> Michael
>>>>>>>>>> Am 31.10.2015 um 14:16 schrieb Robert Cotran:
>>>>>>>>>>> Hi all,
>>>>>>>>>>> I'm replying to Micheal Balzer's email from yesterday. I
>>>>>>>>>>> wasn't on the mailing list until late yesterday afternoon,
>>>>>>>>>>> hence I'm not able to click reply.
>>>>>>>>>>> I've got a Kia Soul EV 2016 in Canada which doesn't have the
>>>>>>>>>>> UVO services, so this is of great interest to me.
>>>>>>>>>>> I have the OVMS kit in front of me, but I'm a total newbie,
>>>>>>>>>>> so I'm reading through some guides to get started.
>>>>>>>>>>> Just wanted to say that I'll gladly be the guinea pig for this.
>>>>>>>>>>> What I'd REALLY like is to have a way to remotely turn on
>>>>>>>>>>> the climate control system to warm up/cool down the car at
>>>>>>>>>>> will. Hopefully that's a remote possibility. Tracking it is
>>>>>>>>>>> cool, but controlling it is even better. I'm used to a
>>>>>>>>>>> Tesla (my other car), so I am quite spoiled.
>>>>>>>>>>> I did get Micheal's firmware installed on the OVMS and
>>>>>>>>>>> hooked it up to the car but it's not booting properly (based
>>>>>>>>>>> on status LEDs). Can that be because of the firmware or is
>>>>>>>>>>> the bootup sequence separate from the car-control code?
>>>>>>>>>>> The LEDs flash like - 10 Green, 9 Green, 10 Green, 9 Green,
>>>>>>>>>>> then a few reds, then green and red flash together really fast.
>>>>>>>>>>> I tried sending text messages to the board and no dice.
>>>>>>>>>>> Any help would be appreciated, looking forward to getting
>>>>>>>>>>> this working!
>>>>>>>>>>> Robert
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> OvmsDev mailing list
>>>>>>>>>>> OvmsDev at lists.teslaclub.hk
>>>>>>>>>>> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
>>>>>>>>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>>>>>>>>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
>>>>>>>>> OvmsDev at lists.teslaclub.hk <mailto:OvmsDev at lists.teslaclub.hk>
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20151104/8f7487de/attachment-0001.html>
