[Ovmsdev] Open Charge map
Tue Nov 3 01:28:43 HKT 2015
Geir,
the OCM charge plugs config should be available in the car editor.
The dialog attached to the battery indicator is meant to configure the
current/next charging session, which is not yet implemented on the Kia
(and likely will need some changes).
Am 02.11.2015 um 14:41 schrieb Geir Øyvind Vælidalo:
> Hi all,
> I'm having trouble seeing chargers on the map in the iOS-app. When I press
> the "Filtered Stations ON" I get a message saying that the selected car
> has no setup of charger type.
> I guess it is talking about the charger settings I get when I press the
> large battery indicator, but whatever I choose here, I get unimplemented
> operation.
> Is this the correct place to register the charger type?
> Do you have any pointers for where to start in the code?
> Best regards,
> Geir
Type: text/x-vcard
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20151102/74de20f0/attachment.vcf>
