[Ovmsdev] Kia Soul EV version 0.1
Sun Nov 1 05:20:08 HKT 2015
Welcome Robert :-)
Basic setup of the Kia firmware is the same as for other models. So you
can follow the Roadster guide or one of the Twizy guides first.
You wrote to me you got the module from a friend, so you should first
flash once without preserving EEPROM to get a clean config to start with.
Follow Marks link to the support FAQ if you get stuck in the config
process. To diag LED flash codes, also take a look at the state machine
diagram in the main docs folder. If you need help, describe exactly (!)
which doc you've been following and what you have done so far.
If you're stuck at 10/9... maybe you should first check if the SIM card
has contact.
Kia V0.1 only reads some first status messages and obtains the VIN if
you enable CAN write access (FEATURE 15 1). I've currently got one
positive and one negative test feedback for this version.
Would be great if you could also check V0.2 -- it's in my account on github:
https://github.com/dexterbg/Open-Vehicle-Monitoring-System
...hex:
http://dexters-web.de/f/kiasoul/OVMS-KiaSoul-0.2.zip
This _should_ be able to show some first OBD diag data dumps (DEBUG 1 /
5)... as I don't have a Kia, I need qualified beta test feedback.
Am 31.10.2015 um 14:16 schrieb Robert Cotran:
> Hi all,
> I'm replying to Micheal Balzer's email from yesterday.  I wasn't on
> the mailing list until late yesterday afternoon, hence I'm not able to
> click reply.
> I've got a Kia Soul EV 2016 in Canada which doesn't have the UVO
> services, so this is of great interest to me.
> I have the OVMS kit in front of me, but I'm a total newbie, so I'm
> reading through some guides to get started.
> Just wanted to say that I'll gladly be the guinea pig for this.
> What I'd REALLY like is to have a way to remotely turn on the climate
> control system to warm up/cool down the car at will. Hopefully that's
> a remote possibility.  Tracking it is cool, but controlling it is even
> better.  I'm used to a Tesla (my other car), so I am quite spoiled.
> I did get Micheal's firmware installed on the OVMS and hooked it up to
> the car but it's not booting properly (based on status LEDs).  Can
> that be because of the firmware or is the bootup sequence separate
> from the car-control code?
> The LEDs flash like - 10 Green, 9 Green, 10 Green, 9 Green, then a few
> reds, then green and red flash together really fast.
> I tried sending text messages to the board and no dice.
> Any help would be appreciated, looking forward to getting this working!
> Robert
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20151031/c4bca947/attachment.html>
Type: text/x-vcard
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20151031/c4bca947/attachment.vcf>
