[Ovmsdev] I could use some help integrating Tasker-support
    Jille Berends
    jjberends at gmail.com
    Fri May  1 20:44:24 HKT 2015
Hmm, I couldn't find much on Automagic, and importing the files needed for
Tasker into Eclipse wasn't that succesful either... back to the drawing
board ;-)
2015-04-23 22:27 GMT+02:00 Jille Berends <jjberends at gmail.com>:
> :) I think Locale is similar as well, at least it shares the same api as
> Tasker. I didn't know Automatic yet, I will check it out tomorrow morning.
> Regards!
>  Op 23 apr. 2015 21:49 schreef "Michael Balzer" <dexter at expeedo.de>:
>  Hi Jille,
>> cool. I'm using "Automagic" and supporting that (if possible) has been on
>> my list as well.
>> I'd like having a general scripting API / plugin to allow all of these
>> Apps.
>> It seems plugins for both Apps are based on the same framework:
>> http://www.twofortyfouram.com/developer.html
>> So it should be possible. Tasker seems to be more advanced regarding
>> plugin support though.
>> Am 23.04.2015 um 13:32 schrieb Jille Berends:
>>  Hi all,
>> I'm in the process of integrating Tasker support in OVMS for Android.
>> For those who don't know about Tasker:
>> "Tasker is an application for Android which performs *tasks* (sets of
>> actions) based on *contexts* (application, time, date, location, event,
>> gesture) in user-defined profiles or in clickable or timer home screen
>> widgets. "
>> Currently I use it to automate all kinds of things, like turning on the
>> lights of my house when my phone sees my access point. But it can also be
>> used to add additional intelligence to our cars. For instance:
>>  - User gets the possibility to charge by schedule. For instance: When
>> at a certain location, charge at 16A from 1:00 to 5:00. charge at 32A at
>> other times.
>> - OVMS-triggered events: Upon charge done, have something happen on the
>> phone. For instance: play a song, send an email, tweet or whatever. Also,
>> in case you're driving and OVMS reports a SOC below a certain value, start
>> the app that finds the nearest charger
>> - Open up variables (like temperature/SOC) for use in Widget-tools like
>> Zooper.
>> - Even more advanced ACC: Set the "charge done by" time according to a
>> given day/time/location.
>> - Log location/charge/speed/temperature data to phone/web
>> - Enable voice control of charging
>> - et cetera
>> My devskills aren't that advanced, so I hope there's someone here I can
>> team up with to get this thing going.
>> Some basic info on enabling Tasker support:
>> http://tasker.dinglisch.net/developers.html
>> http://tasker.dinglisch.net/plugins-intro.html
>> OvmsDev mailing listOvmsDev at lists.teslaclub.hkhttp://lists.teslaclub.hk/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20150501/d8fa47c4/attachment.htm>
