[Ovmsdev] Firmware 2.7.1 / Android 3.8.3
    Tue Mar 24 06:44:53 HKT 2015
Hi Michael,
see my note:
> Note: you'll need the framework update on other cars as well to get
> correct odometer display if using km units.
> And of course you need the framework update to be able to send SMS
> commands via App.
For the Twizy you can use my Firmware download, for other cars you
currently need to compile yourself.
For the social group function: sorry, I'm afraid that's currently very
near to the bottom of my todo list.
Am 23.03.2015 um 21:08 schrieb Michael Gerber:
> sorry app is 3.8.3 ...
> Am 23. März 2015 21:06:16 schrieb Michael Gerber <effizienzx at gmail.com>:
>> Hi Michael,
>> first of all, great Work ...
>> Android App 3.8.1: ODO displays Miles,  but Param #2 is set to K,
>> TR2.5, FW2.6.5
>> Where are the social group settings for the map located?
>> Best Regards
>> Am 23. März 2015 20:36:34 schrieb Michael Balzer <dexter at expeedo.de>:
>>> Android bugfix release 3.8.3 (fixes database creation for new
>>> installs / erased App data):
>>> |http://dexters-web.de/f/tw/oVMS-release-3.8.3.apk|
>>> Am 22.03.2015 um 20:44 schrieb Michael Balzer:
>>>> As Testflight have cancelled their Android support yesterday (great
>>>> timing...), here's the next update removing all Testflight
>>>> dependencies:
>>>> Version 3.8.2:
>>>>     - Fixed trip & odometer processing
>>>>     - Added odometer display on car fragment
>>>>     - Layout improvements
>>>>     - Testflight removed (Android support cancelled yesterday)
>>>>     - Fixed database bug on charge plug config
>>>> APK:
>>>> |http://dexters-web.de/f/tw/oVMS-release-3.8.2.apk|
>>>> Firmware 2.7.2 download:
>>>> |http://dexters-web.de/f/tw/OVMS-Twizy-3.5.1.zip|
>>>> commands via App.
>>>> Regards,
>>>> Michael
>>>> Am 21.03.2015 um 16:47 schrieb Michael Balzer:
>>>>> Framework version 2.7.1:
>>>>>     - New MSG command 7 = SMS command wrapper
>>>>>     - Renamed doors3bits "CoolingPump" to "CarAwake" (as in
>>>>> documentation)
>>>>>     - Fixed potential null pointer dereference on charge alert
>>>>>     - Framework: ETR vars & STAT msg extended by separate range/SOC
>>>>>       estimates + max ideal range
>>>>>     - Consistency fix: new STAT ranges converted to user units
>>>>>     - Documentation: added typical problems to german FAQ
>>>>>     - Documentation: Modem / network state machine diagram
>>>>> Twizy version 3.5.1:
>>>>>     - Clearing watchdog on initial SEVCON login retries
>>>>>     - Fixed logs command return code
>>>>>     - Support for doors3.CarAwake (ignition)
>>>>>     - Trip start references taken from first valid data after
>>>>> switch-on
>>>>> Note: Twizy build now needs diag module to be excluded (ROM space).
>>>>> Firmware download:
>>>>> Android App version 3.8.1:
>>>>>     - Fixed reset logs dialog title
>>>>>     - Fixed parameter loading not ending if last param empty
>>>>>     - Added control button in car list
>>>>>     - Migrated notifications from file storage to SQLite
>>>>>     - Introduced notification types (displayed as icons in list)
>>>>>     - Switched notifications list to chat style (last @ bottom)
>>>>>     - Added sending SMS/MMI commands from notification list
>>>>>       (Note: SMS commands need module firmware >= 2.7.1)
>>>>>     - STAT data model extended by new fields for firmware 2.7.1
>>>>>     - Charge ETR display generalized using new STAT fields
>>>>> APK download:
>>>>> |http://dexters-web.de/f/tw/oVMS-release-3.8.1.apk|
>>>>> Please test & report :-)
>>>>> Regards,
>>>>> Michael
>>>>> Michael Balzer * Paradestr. 8 * D-42107 Wuppertal
>>>>> Fon 0202 / 272 2201 * Handy 0176 / 206 989 26
>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20150323/8b34be61/attachment.htm>
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20150323/8b34be61/attachment-0002.vcf>
