[Ovmsdev] Firmware 2.7.1 / Android 3.8.1
Michael Gerber
effizienzx at gmail.com
Tue Mar 24 04:06:16 HKT 2015
Hi Michael,
first of all, great Work ...
Android App 3.8.1: ODO displays Miles, but Param #2 is set to K, TR2.5,
FW2.6.5
Where are the social group settings for the map located?
Best Regards
Am 23. März 2015 20:36:34 schrieb Michael Balzer <dexter at expeedo.de>:
> Android bugfix release 3.8.3 (fixes database creation for new installs /
> erased App data):
> |http://dexters-web.de/f/tw/oVMS-release-3.8.3.apk|
> Am 22.03.2015 um 20:44 schrieb Michael Balzer:
> > As Testflight have cancelled their Android support yesterday (great
> > timing...), here's the next update removing all Testflight dependencies:
> > Version 3.8.2:
> > - Fixed trip & odometer processing
> > - Added odometer display on car fragment
> > - Layout improvements
> > - Testflight removed (Android support cancelled yesterday)
> > - Fixed database bug on charge plug config
> > APK:
> > |http://dexters-web.de/f/tw/oVMS-release-3.8.2.apk|
> > Firmware 2.7.2 download:
> > |http://dexters-web.de/f/tw/OVMS-Twizy-3.5.1.zip|
> > Note: you'll need the framework update on other cars as well to get
> > correct odometer display if using km units.
> > And of course you need the framework update to be able to send SMS
> > commands via App.
> > Regards,
> > Michael
> > Am 21.03.2015 um 16:47 schrieb Michael Balzer:
> >> Framework version 2.7.1:
> >> - New MSG command 7 = SMS command wrapper
> >> - Renamed doors3bits "CoolingPump" to "CarAwake" (as in
> >> documentation)
> >> - Fixed potential null pointer dereference on charge alert
> >> - Framework: ETR vars & STAT msg extended by separate range/SOC
> >> estimates + max ideal range
> >> - Consistency fix: new STAT ranges converted to user units
> >> - Documentation: added typical problems to german FAQ
> >> - Documentation: Modem / network state machine diagram
> >> Twizy version 3.5.1:
> >> - Clearing watchdog on initial SEVCON login retries
> >> - Fixed logs command return code
> >> - Support for doors3.CarAwake (ignition)
> >> - Trip start references taken from first valid data after switch-on
> >> Note: Twizy build now needs diag module to be excluded (ROM space).
> >> Firmware download:
> >> Android App version 3.8.1:
> >> - Fixed reset logs dialog title
> >> - Fixed parameter loading not ending if last param empty
> >> - Added control button in car list
> >> - Migrated notifications from file storage to SQLite
> >> - Introduced notification types (displayed as icons in list)
> >> - Switched notifications list to chat style (last @ bottom)
> >> - Added sending SMS/MMI commands from notification list
> >> (Note: SMS commands need module firmware >= 2.7.1)
> >> - STAT data model extended by new fields for firmware 2.7.1
> >> - Charge ETR display generalized using new STAT fields
> >> APK download:
> >> |http://dexters-web.de/f/tw/oVMS-release-3.8.1.apk|
> >> Please test & report :-)
> >> Regards,
> >> Michael
> >> Michael Balzer * Paradestr. 8 * D-42107 Wuppertal
> >> Fon 0202 / 272 2201 * Handy 0176 / 206 989 26
> >> _______________________________________________
> >> OvmsDev mailing list
> >> OvmsDev at lists.teslaclub.hk
> >> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20150323/fd1401fa/attachment.htm>
