[Ovmsdev] Firmware 2.7.1 / Android 3.8.3
Michael Gerber
effizienzx at gmail.com
Tue Mar 24 04:08:18 HKT 2015
sorry app is 3.8.3 ...
Am 23. März 2015 21:06:16 schrieb Michael Gerber <effizienzx at gmail.com>:
> Hi Michael,
> first of all, great Work ...
> Android App 3.8.1: ODO displays Miles, but Param #2 is set to K, TR2.5,
> FW2.6.5
> Where are the social group settings for the map located?
> Best Regards
> Am 23. März 2015 20:36:34 schrieb Michael Balzer <dexter at expeedo.de>:
> > Android bugfix release 3.8.3 (fixes database creation for new installs /
> > erased App data):
> > |http://dexters-web.de/f/tw/oVMS-release-3.8.3.apk|
> > Am 22.03.2015 um 20:44 schrieb Michael Balzer:
> > > As Testflight have cancelled their Android support yesterday (great
> > > timing...), here's the next update removing all Testflight dependencies:
> > > Version 3.8.2:
> > > - Fixed trip & odometer processing
> > > - Added odometer display on car fragment
> > > - Layout improvements
> > > - Testflight removed (Android support cancelled yesterday)
> > > - Fixed database bug on charge plug config
> > > APK:
> > > |http://dexters-web.de/f/tw/oVMS-release-3.8.2.apk|
> > > Firmware 2.7.2 download:
> > > |http://dexters-web.de/f/tw/OVMS-Twizy-3.5.1.zip|
> > > Note: you'll need the framework update on other cars as well to get
> > > correct odometer display if using km units.
> > > And of course you need the framework update to be able to send SMS
> > > commands via App.
> > > Regards,
> > > Michael
> > > Am 21.03.2015 um 16:47 schrieb Michael Balzer:
> > >> Framework version 2.7.1:
> > >> - New MSG command 7 = SMS command wrapper
> > >> - Renamed doors3bits "CoolingPump" to "CarAwake" (as in
> > >> documentation)
> > >> - Fixed potential null pointer dereference on charge alert
> > >> - Framework: ETR vars & STAT msg extended by separate range/SOC
> > >> estimates + max ideal range
> > >> - Consistency fix: new STAT ranges converted to user units
> > >> - Documentation: added typical problems to german FAQ
> > >> - Documentation: Modem / network state machine diagram
> > >> Twizy version 3.5.1:
> > >> - Clearing watchdog on initial SEVCON login retries
> > >> - Fixed logs command return code
> > >> - Support for doors3.CarAwake (ignition)
> > >> - Trip start references taken from first valid data after switch-on
> > >> Note: Twizy build now needs diag module to be excluded (ROM space).
> > >> Firmware download:
> > >> Android App version 3.8.1:
> > >> - Fixed reset logs dialog title
> > >> - Fixed parameter loading not ending if last param empty
> > >> - Added control button in car list
> > >> - Migrated notifications from file storage to SQLite
> > >> - Introduced notification types (displayed as icons in list)
> > >> - Switched notifications list to chat style (last @ bottom)
> > >> - Added sending SMS/MMI commands from notification list
> > >> (Note: SMS commands need module firmware >= 2.7.1)
> > >> - STAT data model extended by new fields for firmware 2.7.1
> > >> - Charge ETR display generalized using new STAT fields
> > >> APK download:
> > >> |http://dexters-web.de/f/tw/oVMS-release-3.8.1.apk|
> > >> Please test & report :-)
> > >> Regards,
> > >> Michael
> > >> Michael Balzer * Paradestr. 8 * D-42107 Wuppertal
> > >> Fon 0202 / 272 2201 * Handy 0176 / 206 989 26
> > >> _______________________________________________
> > >> OvmsDev mailing list
> > >> OvmsDev at lists.teslaclub.hk
> > >> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20150323/def6547b/attachment-0001.html>
