[Ovmsdev] Firmware 2.7.1 / Android 3.8.1
Tue Mar 24 03:36:18 HKT 2015
Android bugfix release 3.8.3 (fixes database creation for new installs /
erased App data):
|http://dexters-web.de/f/tw/oVMS-release-3.8.3.apk|
Am 22.03.2015 um 20:44 schrieb Michael Balzer:
> As Testflight have cancelled their Android support yesterday (great
> timing...), here's the next update removing all Testflight dependencies:
> Version 3.8.2:
> - Fixed trip & odometer processing
> - Added odometer display on car fragment
> - Layout improvements
> - Testflight removed (Android support cancelled yesterday)
> - Fixed database bug on charge plug config
> APK:
> |http://dexters-web.de/f/tw/oVMS-release-3.8.2.apk|
> Firmware 2.7.2 download:
> |http://dexters-web.de/f/tw/OVMS-Twizy-3.5.1.zip|
> Note: you'll need the framework update on other cars as well to get
> correct odometer display if using km units.
> And of course you need the framework update to be able to send SMS
> commands via App.
> Am 21.03.2015 um 16:47 schrieb Michael Balzer:
>> Framework version 2.7.1:
>> - New MSG command 7 = SMS command wrapper
>> - Renamed doors3bits "CoolingPump" to "CarAwake" (as in
>> documentation)
>> - Fixed potential null pointer dereference on charge alert
>> - Framework: ETR vars & STAT msg extended by separate range/SOC
>> estimates + max ideal range
>> - Consistency fix: new STAT ranges converted to user units
>> - Documentation: added typical problems to german FAQ
>> - Documentation: Modem / network state machine diagram
>> Twizy version 3.5.1:
>> - Clearing watchdog on initial SEVCON login retries
>> - Fixed logs command return code
>> - Support for doors3.CarAwake (ignition)
>> - Trip start references taken from first valid data after switch-on
>> Note: Twizy build now needs diag module to be excluded (ROM space).
>> Firmware download:
>> Android App version 3.8.1:
>> - Fixed reset logs dialog title
>> - Fixed parameter loading not ending if last param empty
>> - Added control button in car list
>> - Migrated notifications from file storage to SQLite
>> - Introduced notification types (displayed as icons in list)
>> - Switched notifications list to chat style (last @ bottom)
>> - Added sending SMS/MMI commands from notification list
>> (Note: SMS commands need module firmware >= 2.7.1)
>> - STAT data model extended by new fields for firmware 2.7.1
>> - Charge ETR display generalized using new STAT fields
>> APK download:
>> |http://dexters-web.de/f/tw/oVMS-release-3.8.1.apk|
>> Please test & report :-)
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20150323/35fe7979/attachment.html>
Type: text/x-vcard
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20150323/35fe7979/attachment.vcf>
