[Ovmsdev] Firmware 2.7.1 / Android 3.8.1
Mon Mar 23 03:44:46 HKT 2015
As Testflight have cancelled their Android support yesterday (great
timing...), here's the next update removing all Testflight dependencies:
Version 3.8.2:
- Fixed trip & odometer processing
- Added odometer display on car fragment
- Layout improvements
- Testflight removed (Android support cancelled yesterday)
- Fixed database bug on charge plug config
APK:
|http://dexters-web.de/f/tw/oVMS-release-3.8.2.apk|
Firmware 2.7.2 download:
|http://dexters-web.de/f/tw/OVMS-Twizy-3.5.1.zip|
Note: you'll need the framework update on other cars as well to get
correct odometer display if using km units.
And of course you need the framework update to be able to send SMS
commands via App.
Am 21.03.2015 um 16:47 schrieb Michael Balzer:
> Framework version 2.7.1:
> - New MSG command 7 = SMS command wrapper
> - Renamed doors3bits "CoolingPump" to "CarAwake" (as in documentation)
> - Fixed potential null pointer dereference on charge alert
> - Framework: ETR vars & STAT msg extended by separate range/SOC
> estimates + max ideal range
> - Consistency fix: new STAT ranges converted to user units
> - Documentation: added typical problems to german FAQ
> - Documentation: Modem / network state machine diagram
> Twizy version 3.5.1:
> - Clearing watchdog on initial SEVCON login retries
> - Fixed logs command return code
> - Support for doors3.CarAwake (ignition)
> - Trip start references taken from first valid data after switch-on
> Note: Twizy build now needs diag module to be excluded (ROM space).
> Firmware download:
> Android App version 3.8.1:
> - Fixed reset logs dialog title
> - Fixed parameter loading not ending if last param empty
> - Added control button in car list
> - Migrated notifications from file storage to SQLite
> - Introduced notification types (displayed as icons in list)
> - Switched notifications list to chat style (last @ bottom)
> - Added sending SMS/MMI commands from notification list
> (Note: SMS commands need module firmware >= 2.7.1)
> - STAT data model extended by new fields for firmware 2.7.1
> - Charge ETR display generalized using new STAT fields
> APK download:
> |http://dexters-web.de/f/tw/oVMS-release-3.8.1.apk|
> Please test & report :-)
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20150322/eb874479/attachment.html>
Type: text/x-vcard
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20150322/eb874479/attachment.vcf>
