[Ovmsdev] Firmware 2.7.1 / Android 3.8.1
Sat Mar 21 23:47:22 HKT 2015
Framework version 2.7.1:
- New MSG command 7 = SMS command wrapper
- Renamed doors3bits "CoolingPump" to "CarAwake" (as in documentation)
- Fixed potential null pointer dereference on charge alert
- Framework: ETR vars & STAT msg extended by separate range/SOC
estimates + max ideal range
- Consistency fix: new STAT ranges converted to user units
- Documentation: added typical problems to german FAQ
- Documentation: Modem / network state machine diagram
Twizy version 3.5.1:
- Clearing watchdog on initial SEVCON login retries
- Fixed logs command return code
- Support for doors3.CarAwake (ignition)
- Trip start references taken from first valid data after switch-on
Note: Twizy build now needs diag module to be excluded (ROM space).
Firmware download:
|http://dexters-web.de/f/tw/OVMS-Twizy-3.5.1.zip|
Android App version 3.8.1:
- Fixed reset logs dialog title
- Fixed parameter loading not ending if last param empty
- Added control button in car list
- Migrated notifications from file storage to SQLite
- Introduced notification types (displayed as icons in list)
- Switched notifications list to chat style (last @ bottom)
- Added sending SMS/MMI commands from notification list
(Note: SMS commands need module firmware >= 2.7.1)
- STAT data model extended by new fields for firmware 2.7.1
- Charge ETR display generalized using new STAT fields
APK download:
|http://dexters-web.de/f/tw/oVMS-release-3.8.1.apk|
Please test & report :-)
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20150321/9adb64d7/attachment.html>
Type: text/x-vcard
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20150321/9adb64d7/attachment.vcf>
