[Ovmsdev] Fwd: Re:  App for Windows Phone?
    Christopher Cook
    christopher.cook at webprofusion.com
    Thu Jun  4 11:36:16 HKT 2015
I've thought about this before but not being an OVMS user means I just
don't have the motivation (sorry!)
A long term cross platform solution would be to develop using Xamarin
then much of the (C#) code could be shared across platforms. A basic
shared UI can be done using Xamarin Forms but the tricky part of an OVMS
app isn't really the UI, it's the server comms/decoding/encoding.
Another alternative is allow an HTML UI for the app (as we use for Open
Charge Map) which would require a native Cordova plugin for each
supported platform to do the low level comms/translation. The plugin
would expose a high level api to the app to pass in/out JSON objects
that the javascript based app can then use.
Alternatively a full HTTP or Websockets based server API that any app
can use would remove the need for a native component (standard
javascript can't talk to normal sockets).
Chris
On 02/06/2015 14:35, Jille Berends wrote:
> According to the news, MS is working on a way to get Android apps
> running on Windows mobile:
> http://www.techtimes.com/articles/49681/20150502/android-apps-coming-windows-phones-will-help-resurrect-microsofts-mobile.htm
> 2015-05-28 3:49 GMT+02:00 Mark Webb-Johnson <mark at webb-johnson.net
> <mailto:mark at webb-johnson.net>>:
>     Not that I know of.
>     Regards, Mark.
>     > On 28 May, 2015, at 1:53 am, Michael Jochum <mikeljo at me.com
>     <mailto:mikeljo at me.com>> wrote:
>     > Hi,
>     > i have an inquire: is there is an OVMS App for WP8?
>     > Not for me, i use iPhone ;-) But i know there is something
>     others outside :-)
>     > Bye
>     > Michael
>     > _______________________________________________
>     > OvmsDev mailing list
>     > OvmsDev at lists.teslaclub.hk <mailto:OvmsDev at lists.teslaclub.hk>
>     > http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
Christopher Cook
Open Charge Map
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20150604/29454aee/attachment.htm>
