[Ovmsdev] understanding polling
Mon Jun 22 21:12:00 HKT 2015
The Ampera is still using the old polling logic. The poling code is within the vehicle_voltampera module itself.
The Leaf is using the new centralised polling logic (in vehicle.h and vehicle.c). This is the new recommend way of doing this, as the vehicle.{h,c} code will do the polling for you - all you need to do is setup the appropriate structure.
The new structure is:
typedef struct
unsigned int moduleid;
unsigned int rmoduleid;
unsigned char type;
unsigned int pid;
unsigned int polltime[VEHICLE_POLL_NSTATES];
} vehicle_pid_t;
and the following polling types are currently supported:
#define VEHICLE_POLL_TYPE_NONE 0x00
#define VEHICLE_POLL_TYPE_OBDIICURRENT 0x01
#define VEHICLE_POLL_TYPE_OBDIIVEHICLE 0x09
#define VEHICLE_POLL_TYPE_OBDIIGROUP 0x21
#define VEHICLE_POLL_TYPE_OBDIIEXTENDED 0x22
The moduleid is the replying module id, the rmoduleid is the id to use for the request.
> On 21 Jun, 2015, at 9:44 pm, Nikolay Shishkov <nshishkov at yahoo.com> wrote:
> Hi ,
> I am trying to make nissan leaf work with normal cable - on the CARCAN.
> I am trying to figure out the polling mechanism and I have trouble understanding what the different parameters in the configurations are.
> In the ampera file I can see:
> rom struct
> unsigned char polltime;
> unsigned int pid;
> } vehicle_voltampera_polls[]
> { 0x07E0, 10, 0x000D },
> { 0x07E4, 10, 0x4369 },
> { 0x07E4, 10, 0x4368 },
> { 0x07E4, 10, 0x801f },
> { 0x07E4, 10, 0x801e },
> { 0x07E4, 10, 0x434f },
> { 0x07E4, 10, 0x1c43 },
> { 0x07E4, 10, 0x8334 },
> { 0x07E1, 100, 0x2487 },
> { 0x0000, 0, 0x0000 }
> While in the nissan leaf file I can see the following:
> rom vehicle_pid_t vehicle_nissanleaf_polls[]
> { 0x797, 0x79a, VEHICLE_POLL_TYPE_OBDIICURRENT, 0x0d, { 10, 10, 0 } }, // Speed
> { 0x797, 0x79a, VEHICLE_POLL_TYPE_OBDIIVEHICLE, 0x02, { 10, 10, 0 } }, // VIN
> { 0, 0, 0x00, 0x00, { 0, 0, 0 } }
> I can kind of guess some of it.
> I also found an old e-mail from Mark that describes a structure similar to the one in the nissan leaf file, but the leaf has one extra parameter - I think it is the return message can Id.
> Any info/advice is appreciated!
> Nikolay
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20150622/60e7e3f8/attachment-0001.html>
