[Ovmsdev] I could use some help integrating Tasker-support
Jille Berends
jjberends at gmail.com
Fri Jun 19 23:47:07 HKT 2015
All right, I give up... Tasker/Locale plugins are not my cup of tea, it's
like their guides are written in a completely different language. After
spending almost an entire working day on trying to getting just a simple
plugin to work with OVMS and Tasker, my console is still a sad gigantic
pool of errors...
Michael, did you find out anything regarding Automagic?
2015-05-01 14:44 GMT+02:00 Jille Berends <jjberends at gmail.com>:
> Hmm, I couldn't find much on Automagic, and importing the files needed for
> Tasker into Eclipse wasn't that succesful either... back to the drawing
> board ;-)
> 2015-04-23 22:27 GMT+02:00 Jille Berends <jjberends at gmail.com>:
>> :) I think Locale is similar as well, at least it shares the same api as
>> Tasker. I didn't know Automatic yet, I will check it out tomorrow morning.
>> Regards!
>> Op 23 apr. 2015 21:49 schreef "Michael Balzer" <dexter at expeedo.de>:
>> Hi Jille,
>>> cool. I'm using "Automagic" and supporting that (if possible) has been
>>> on my list as well.
>>> I'd like having a general scripting API / plugin to allow all of these
>>> Apps.
>>> It seems plugins for both Apps are based on the same framework:
>>> http://www.twofortyfouram.com/developer.html
>>> So it should be possible. Tasker seems to be more advanced regarding
>>> plugin support though.
>>> Am 23.04.2015 um 13:32 schrieb Jille Berends:
>>> Hi all,
>>> I'm in the process of integrating Tasker support in OVMS for Android.
>>> For those who don't know about Tasker:
>>> "Tasker is an application for Android which performs *tasks* (sets of
>>> actions) based on *contexts* (application, time, date, location, event,
>>> gesture) in user-defined profiles or in clickable or timer home screen
>>> widgets. "
>>> Currently I use it to automate all kinds of things, like turning on the
>>> lights of my house when my phone sees my access point. But it can also be
>>> used to add additional intelligence to our cars. For instance:
>>> - User gets the possibility to charge by schedule. For instance: When
>>> at a certain location, charge at 16A from 1:00 to 5:00. charge at 32A at
>>> other times.
>>> - OVMS-triggered events: Upon charge done, have something happen on the
>>> phone. For instance: play a song, send an email, tweet or whatever. Also,
>>> in case you're driving and OVMS reports a SOC below a certain value, start
>>> the app that finds the nearest charger
>>> - Open up variables (like temperature/SOC) for use in Widget-tools like
>>> Zooper.
>>> - Even more advanced ACC: Set the "charge done by" time according to a
>>> given day/time/location.
>>> - Log location/charge/speed/temperature data to phone/web
>>> - Enable voice control of charging
>>> - et cetera
>>> My devskills aren't that advanced, so I hope there's someone here I can
>>> team up with to get this thing going.
>>> Some basic info on enabling Tasker support:
>>> http://tasker.dinglisch.net/developers.html
>>> http://tasker.dinglisch.net/plugins-intro.html
>>> OvmsDev mailing listOvmsDev at lists.teslaclub.hkhttp://lists.teslaclub.hk/mailman/listinfo/ovmsdev
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20150619/2412f8a4/attachment.html>
