[Ovmsdev] Registered phone / password security issue
Wed Jul 22 19:18:59 HKT 2015
Tom, Mark,
I haven't tried myself, but the code is quite clear:
https://github.com/openvehicles/Open-Vehicle-Monitoring-System/blob/master/vehicle/OVMS.X/net_sms.c#L237
strlen(p) is 0 on an empty REGPHONE, so the result
is true. Only "REGISTER" and "AP" need the
password, all other commands should succeed from
any phone with an empty REGPHONE.
The acc module is not included in the Twizy
firmware (due to ROM space).
Securing par_write() is a good idea, but the data
loss need not have been caused by a par_write()
operation. I know of at least one user module that
loses and garbles EEPROM contents frequently.
There may be some general hardware issue, at least
with the modules delivered during the last 6-9
months or so.
I'm also having single byte EEPROM errors
occasionally after flashing. These mostly affect
the first byte of some parameter slot, only bit
flips up to now but a change to 0 would empty that
slot.
If I can confirm the problem I will include both
the par_write() securing and the auth fail-close
change into the fix.
Am 22.07.2015 um 04:02 schrieb Mark Webb-Johnson:
> Michael, Tom,
> Not sure how the entire EEPROM can be erased.
> The code in par_write(), par_set() and
> par_setbin() seems to limit the write
> to PARAM_MAX_LENGTH. The EEPROM can’t be
> overwritten by normal code and it takes quite a
> bit of register mashing to write to it. Can
> someone have a look over the params.c functions
> and see if you have any guesses as to the cause?
> I think it is important to identify the root cause.
> I did fix an error in the acc code, December
> last year, that caused an off-by-one parameter
> to be set:
> commit 5269c870b1858f58098b16b39d10beb2b0e3b330
> Author: Mark Webb-Johnson
> <mark at webb-johnson.net
> <mailto:mark at webb-johnson.net>>
> Date: Mon Dec 8 13:11:32 2014 +0800
> Setting acc params, without location,
> when not in a location, leads to off-by-one
> index parameter write
> diff --git a/vehicle/OVMS.X/acc.c
> b/vehicle/OVMS.X/acc.c
> index 4935590..1bf430c 100644
> --- a/vehicle/OVMS.X/acc.c
> +++ b/vehicle/OVMS.X/acc.c
> @@ -948,7 +948,7 @@ BOOL acc_cmd_params(BOOL
> sms, char* caller, char *arguments)
> net_send_sms_start(caller);
> - if (k<0)
> + if (k<=0)
> s = stp_rom(net_scratchpad,ACC_NOTHERE);
> That is in the development branch, but is not in
> the standard firmware. But, the worst affect of
> that would be to overwrite PARAM_COOLDOWN (#15)
> (and easy to see as the overwritten value is
> base64).
> It seems to be that params.c sets the default
> values to be:
> #0 PARAM_REGPHONE = NOPHONE
> #1 PARAM_MODULEPASS = OVMS
> #2 PARAM_MILESKM = K
> My only concern with removing the fail-open to
> both PARAM_REGPHONE (net_sms_checkcaller)
> */and/* PARAM_MODULEPASS (net_sms_checkpassarg)
> is that if they were both blank then the user
> would be completely locked out of the module.
> Only solution would be a complete re-flash and
> reset to default parameters.
> Another option would be to hard-code change
> par_write() to *refuse* to write a blank
> password to #1. Then, we could go ahead and
> change net_sms_checkcaller() to not fail open
> for registered phone number. From what I can
> see, *all* writes to EEPROM go through
> par_write() in params.c.
>> On 22 Jul, 2015, at 8:39 am, Tom Saxton
>> <tom at idleloop.com <mailto:tom at idleloop.com>> wrote:
>> Hi Michael,
>> Have you confirmed the security problem? I've
>> had time when the EEPROM got
>> zeroed out and I couldn't access the module via
>> SMS at all. I had to
>> reflash with a valid EEPROM image in order to
>> re-register my cell number.
>> I'm pretty careful not to share my OVMS phone
>> number with anyone. If
>> someone unfriendly had it, they could send it a
>> bunch of SMS messages each
>> of which costs me a penny. Do that 1,000 times,
>> and they've disabled my
>> box until I refill my H2O account.
>> Tom
>> -----Original Message-----
>> From: Michael Balzer <dexter at expeedo.de
>> <mailto:dexter at expeedo.de>>
>> Reply-To: OVMS Developers
>> <ovmsdev at lists.teslaclub.hk
>> <mailto:ovmsdev at lists.teslaclub.hk>>
>> Date: Tuesday, July 21, 2015 at 9:23 AM
>> To: OVMS Developers <ovmsdev at lists.teslaclub.hk
>> Subject: [Ovmsdev] Registered phone / password
>> security issue
>>> Hi everyone,
>>> some users including me experienced loss or
>>> garbling of eeprom
>>> parameters. I once saw by chance that my
>>> registered phone number had
>>> turned empty -- I seldom need to use SMS, so I
>>> only saw this when
>>> checking the parameter list on the App for
>>> another config.
>>> The same now also occured to another user I'm
>>> in contact with, and it
>>> now turned out that's not only annoying but a
>>> security issue:
>>> The current logic of net_sms_checkcaller()
>>> allows access to any phone
>>> number if the parameter is empty. The same
>>> applies to
>>> net_sms_checkpassarg(), which will allow any
>>> password to be used if no
>>> password is stored.
>>> As this kind of data loss can only be detected
>>> by checking the
>>> parameters, it's possible to check for "open"
>>> modules by just trying to
>>> access them from time to time -- you only need
>>> to know the SIM card
>>> number.
>>> I'm about to submit a change for both
>>> functions to NOT allow access if
>>> their respective param slots are empty.
>>> As the initial flash contents has the "OVMS"
>>> standard password, a
>>> completely lost module should still be
>>> restorable by re-flashing.
>>> Do I miss something? Is there any reason for
>>> the "empty=wildcard"
>>> behaviour?
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20150722/7bcd6b4c/attachment.htm>
