[Ovmsdev] web api
Wed Jul 1 17:49:23 HKT 2015
Here’s my test:
$  curl -s -X GET -c ~/Downloads/ovms-cookie -v "https://tmc.openvehicles.com:6869/api/cookie?username=USER&password=PASSWORD <https://tmc.openvehicles.com:6869/api/cookie?username=USER&password=PASSWORD>
* Hostname was NOT found in DNS cache
*   Trying 54.243.136.230...
* Connected to tmc.openvehicles.com (54.243.136.230) port 6869 (#0)
* TLS 1.2 connection using TLS_DHE_RSA_WITH_AES_256_CBC_SHA256
* Server certificate: tmc.openvehicles.com
* Server certificate: COMODO RSA Domain Validation Secure Server CA
* Server certificate: COMODO RSA Certification Authority
* Server certificate: AddTrust External CA Root
> GET /api/cookie?username=USER&password=PASSWORD HTTP/1.1
> User-Agent: curl/7.37.1
> Host: tmc.openvehicles.com:6869
> Accept: */*
* HTTP 1.0, assume close after body
< HTTP/1.0 200 Authentication ok
< Content-Type: text/plain
< Expires: Wed, 01 Jul 2015 09:46:18 GMT
* Added cookie ovmsapisession=“<REDACTED>" for domain tmc.openvehicles.com, path /api/, expire 0
< Set-Cookie: ovmsapisession=<REDACTED>
< Connection: close
< Cache-Control: max-age=0
< Content-Length: 9
< Access-Control-Allow-Origin: *
< Date: Wed, 01 Jul 2015 09:46:18 GMT
Login ok
Also tried 6868 for http, and ok.
What is the error you are getting?
> On 1 Jul, 2015, at 5:41 pm, Nikolay Shishkov <nshishkov at yahoo.com> wrote:
> The following one:
> http://tmc.openvehicles.com:6868/api/cookie <http://tmc.openvehicles.com:6868/api/cookie>
> Should I use another one?
> On Wednesday, July 1, 2015 11:39 AM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> Seems ok for me. What URL are you using?
>> On 1 Jul, 2015, at 4:25 pm, Nikolay Shishkov <nshishkov at yahoo.com <mailto:nshishkov at yahoo.com>> wrote:
>> Hi Mark,
>> The web api seem to be inaccessible. Is it me or is it the server?
>> Nikolay
> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20150701/68907ff7/attachment.htm>
