[Ovmsdev] web api
Christopher Cook
christopher.cook at webprofusion.com
Thu Jul 2 17:33:27 HKT 2015
If you ever need to test your connection to anything (web/smtp/databases etc) try using a telnet client (an installable feature on windows)
telnet <hostname> <port>
If you get a timeout then the host or port is not accessible to you (firewalled). A blank screen on the other hand indicates a successful connection.
Chris
Sent from my Samsung Galaxy smartphone.-------- Original message --------From: Nikolay Shishkov <nshishkov at yahoo.com> Date: 01/07/2015 11:01 am (GMT+00:00) To: OVMS Developers <ovmsdev at lists.teslaclub.hk> Subject: Re: [Ovmsdev] web api
I was able to log in fine from another network... I will chase down if it is our IT or the internet provider that is blocking traffic.Thanks again for the help,Nikolay
On Wednesday, July 1, 2015 11:54 AM, Nikolay Shishkov <nshishkov at yahoo.com> wrote:
Thanks Mark, I am getting ERR_CONNECTION_TIMED_OUT
I will try from another network... I am starting to have a suspission that our IT blocked some ports...
Nikolay
On Wednesday, July 1, 2015 11:49 AM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
Here’s my test:
$ curl -s -X GET -c ~/Downloads/ovms-cookie -v "https://tmc.openvehicles.com:6869/api/cookie?username=USER&password=PASSWORD* Hostname was NOT found in DNS cache* Trying 54.243.136.230...* Connected to tmc.openvehicles.com (54.243.136.230) port 6869 (#0)* TLS 1.2 connection using TLS_DHE_RSA_WITH_AES_256_CBC_SHA256* Server certificate: tmc.openvehicles.com* Server certificate: COMODO RSA Domain Validation Secure Server CA* Server certificate: COMODO RSA Certification Authority* Server certificate: AddTrust External CA Root> GET /api/cookie?username=USER&password=PASSWORD HTTP/1.1> User-Agent: curl/7.37.1> Host: tmc.openvehicles.com:6869> Accept: */*>* HTTP 1.0, assume close after body< HTTP/1.0 200 Authentication ok< Content-Type: text/plain< Expires: Wed, 01 Jul 2015 09:46:18 GMT* Added cookie ovmsapisession=“<REDACTED>" for domain tmc.openvehicles.com, path /api/, expire 0< Set-Cookie: ovmsapisession=<REDACTED>< Connection: close< Cache-Control: max-age=0< Content-Length: 9< Access-Control-Allow-Origin: *< Date: Wed, 01 Jul 2015 09:46:18 GMT<Login ok
Also tried 6868 for http, and ok.
What is the error you are getting?
On 1 Jul, 2015, at 5:41 pm, Nikolay Shishkov <nshishkov at yahoo.com> wrote:
The following one:http://tmc.openvehicles.com:6868/api/cookie
Should I use another one?
On Wednesday, July 1, 2015 11:39 AM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
Seems ok for me. What URL are you using?
On 1 Jul, 2015, at 4:25 pm, Nikolay Shishkov <nshishkov at yahoo.com> wrote:
Hi Mark,
The web api seem to be inaccessible. Is it me or is it the server?
Nikolay_______________________________________________
OvmsDev mailing list
OvmsDev at lists.teslaclub.hk
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20150702/87517db9/attachment.html>
