[Ovmsdev] Android update 3.2.3
Sat Jan 24 21:25:42 HKT 2015
Marcos,
my last test build can be downloaded and installed from here:
|http://dexters-web.de/f/tw/oVMS-release.apk|
...but I haven't found the solution to the version compatibility issue
yet, according to another tester it will only show OCM markers correctly
on Android 5.x.
Am 24.01.2015 um 13:34 schrieb Marcos Mezo:
> Would you consider adding the aplications to an alternative market? I
> was thinking of f-droid since it is specially for open-source software.
> I have a mostly google free phone without any account and would
> greatly apreciate it.
> Thank you,
> Marcos
>> Michael,
>> I've added you to the maintainers list for the Android repository.
>> On 17 Jan, 2015, at 10:38 pm, Michael Balzer <dexter at expeedo.de
>>> Hi again,
>>> the directory structure changes are not that complex, it's just
>>> another root directory and the sources subdirectory is named "java"
>>> instead of "src".
>>> So here are my changes so far:
>>> https://github.com/dexterbg/Open-Vehicle-Android/commit/56445e31a3de48dfde97956ce70b1153f6729922
>>> Version 3.2.3:
>>> - OCM API update: fixes missing stations, missing detail data
>>> and station address encoding issues
>>> - USSD code dialog is now text field allowing "*" and "#",
>>> default "*100#" (account balance query in most networks)
>>> - 12V battery state display (car info)
>>> - Renault Twizy: "Homelink" gets "Profile" and extended by "Default"
>>> Mark, you need to pull this or add me, I cannot push into the
>>> project repository.
>>> Haven't begun on the range switch, I'm stuck building for my Android
>>> 2.3.5 phone -- everything works except the OCM markers, and the log
>>> contains lots of resolver errors (see below). Tried different build
>>> settings and also replacing the google-play-services.jar, but
>>> nothing helps so far.
>>> It must be some build config, as it runs perfectly on my 5.0.2
>>> tablet. If anyone's got an idea on this, let me know.
>>> Resolver errors on Android 2.3.5:
>>> 01-17 13:31:56.788 7099-7099/com.openvehicles.OVMS W/dalvikvm﹕
>>> VFY: unable to find class referenced in signature
>>> (Landroid/app/Fragment;)
>>> VFY: unable to resolve virtual method 90:
>>> Landroid/app/Activity;.getFragmentManager
>>> ()Landroid/app/FragmentManager;
>>> 01-17 13:31:56.948 7099-7099/com.openvehicles.OVMS W/dalvikvm﹕
>>> VFY: unable to resolve virtual method 6780:
>>> Lcom/actionbarsherlock/internal/nineoldandroids/widget/NineFrameLayout;.onHoverEvent
>>> (Landroid/view/MotionEvent;)Z
>>> 01-17 13:31:56.958 7099-7099/com.openvehicles.OVMS W/dalvikvm﹕
>>> VFY: unable to resolve virtual method 5406:
>>> Landroid/widget/FrameLayout;.getAlpha ()F
>>> VFY: unable to resolve virtual method 5408:
>>> Landroid/widget/FrameLayout;.getTranslationY ()F
>>> VFY: unable to resolve virtual method 5412:
>>> Landroid/widget/FrameLayout;.setAlpha (F)V
>>> VFY: unable to resolve virtual method 5420:
>>> Landroid/widget/FrameLayout;.setTranslationY (F)V
>>> 01-17 13:31:56.968 7099-7099/com.openvehicles.OVMS W/dalvikvm﹕
>>> VFY: unable to resolve virtual method 5100:
>>> Landroid/view/ViewGroup;.getAlpha ()F
>>> VFY: unable to resolve virtual method 5111:
>>> Landroid/view/ViewGroup;.getTranslationX ()F
>>> 01-17 13:31:56.978 7099-7099/com.openvehicles.OVMS W/dalvikvm﹕
>>> VFY: unable to resolve virtual method 5112:
>>> Landroid/view/ViewGroup;.getTranslationY ()F
>>> VFY: unable to resolve virtual method 5134:
>>> Landroid/view/ViewGroup;.setAlpha (F)V
>>> VFY: unable to resolve virtual method 5139:
>>> Landroid/view/ViewGroup;.setTranslationX (F)V
>>> VFY: unable to resolve virtual method 5140:
>>> Landroid/view/ViewGroup;.setTranslationY (F)V
>>> 01-17 13:31:57.008 7099-7099/com.openvehicles.OVMS W/dalvikvm﹕
>>> VFY: unable to resolve virtual method 7644:
>>> Lcom/actionbarsherlock/internal/widget/ActionBarView$HomeView;.onHoverEvent
>>> VFY: unable to resolve virtual method 5410:
>>> Landroid/widget/FrameLayout;.onPopulateAccessibilityEvent
>>> (Landroid/view/accessibility/AccessibilityEvent;)V
>>> 01-17 13:31:57.049 7099-7099/com.openvehicles.OVMS W/dalvikvm﹕
>>> VFY: unable to resolve virtual method 4995:
>>> Landroid/view/View;.jumpDrawablesToCurrentState ()V
>>> VFY: unable to resolve virtual method 5003:
>>> Landroid/view/View;.onInitializeAccessibilityEvent
>>> VFY: unable to resolve static method 5027:
>>> Landroid/view/View;.resolveSizeAndState (III)I
>>> 01-17 13:31:57.079 7099-7099/com.openvehicles.OVMS W/dalvikvm﹕
>>> VFY: unable to resolve static method 7853:
>>> Lcom/actionbarsherlock/internal/widget/IcsAbsSpinner;.resolveSizeAndState
>>> (III)I
>>> 01-17 13:31:57.089 7099-7099/com.openvehicles.OVMS W/dalvikvm﹕
>>> VFY: unable to resolve virtual method 5117:
>>> Landroid/view/ViewGroup;.onInitializeAccessibilityEvent
>>> (Landroid/view/accessibility/AccessibilityNodeInfo;)
>>> VFY: unable to resolve virtual method 5118:
>>> Landroid/view/ViewGroup;.onInitializeAccessibilityNodeInfo
>>> (Landroid/view/accessibility/AccessibilityNodeInfo;)V
>>> VFY: unable to resolve virtual method 5122:
>>> Landroid/view/ViewGroup;.onRequestSendAccessibilityEvent
>>> (Landroid/view/View;Landroid/view/accessibility/AccessibilityEvent;)Z
>>> 01-17 13:31:57.099 7099-7099/com.openvehicles.OVMS W/dalvikvm﹕
>>> VFY: unable to resolve direct method 5551:
>>> Landroid/widget/PopupWindow;.<init>
>>> (Landroid/content/Context;Landroid/util/AttributeSet;II)V
>>> 01-17 13:31:57.109 7099-7099/com.openvehicles.OVMS
>>> E/ResourceType﹕ Style contains key with bad entry: 0x01000000
>>> 01-17 13:31:57.109 7099-7099/com.openvehicles.OVMS W/dalvikvm﹕
>>> VFY: unable to resolve virtual method 5473:
>>> Landroid/widget/LinearLayout;.getAlpha ()F
>>> VFY: unable to resolve virtual method 5476:
>>> Landroid/widget/LinearLayout;.getTranslationX ()F
>>> VFY: unable to resolve virtual method 5488:
>>> Landroid/widget/LinearLayout;.setAlpha (F)V
>>> VFY: unable to resolve virtual method 5498:
>>> Landroid/widget/LinearLayout;.setTranslationX (F)V
>>> 01-17 13:31:57.249 7099-7100/com.openvehicles.OVMS E/Database﹕
>>> close() was never explicitly called on database
>>> '/data/data/com.openvehicles.OVMS/databases/sampledatabase'
>>> android.database.sqlite.DatabaseObjectNotClosedException:
>>> Application did not close the cursor or database object that was
>>> opened here
>>> at
>>> android.database.sqlite.SQLiteDatabase.<init>(SQLiteDatabase.java:1960)
>>> at
>>> android.database.sqlite.SQLiteDatabase.openDatabase(SQLiteDatabase.java:906)
>>> at
>>> android.database.sqlite.SQLiteDatabase.openOrCreateDatabase(SQLiteDatabase.java:940)
>>> at
>>> android.database.sqlite.SQLiteDatabase.openOrCreateDatabase(SQLiteDatabase.java:933)
>>> at
>>> android.app.ContextImpl.openOrCreateDatabase(ContextImpl.java:614)
>>> at
>>> android.content.ContextWrapper.openOrCreateDatabase(ContextWrapper.java:203)
>>> at
>>> android.database.sqlite.SQLiteOpenHelper.getWritableDatabase(SQLiteOpenHelper.java:118)
>>> at
>>> com.openvehicles.OVMS.ui.utils.Database.get_ConnectionTypes_Main(Database.java:222)
>>> at
>>> com.openvehicles.OVMS.utils.ConnectionList.<init>(ConnectionList.java:46)
>>> at
>>> com.openvehicles.OVMS.ui.MainActivity.onCreate(MainActivity.java:59)
>>> at
>>> android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1072)
>>> at
>>> android.app.ActivityThread.performLaunchActivity(ActivityThread.java:1836)
>>> at
>>> android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:1893)
>>> at
>>> android.app.ActivityThread.access$1500(ActivityThread.java:135)
>>> at
>>> android.app.ActivityThread$H.handleMessage(ActivityThread.java:1054)
>>> at android.os.Handler.dispatchMessage(Handler.java:99)
>>> at android.os.Looper.loop(Looper.java:150)
>>> at android.app.ActivityThread.main(ActivityThread.java:4385)
>>> at java.lang.reflect.Method.invokeNative(Native Method)
>>> at java.lang.reflect.Method.invoke(Method.java:507)
>>> at
>>> com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:849)
>>> at
>>> com.android.internal.os.ZygoteInit.main(ZygoteInit.java:607)
>>> at dalvik.system.NativeStart.main(Native Method)
>>> 01-17 13:31:57.879 7099-7099/com.openvehicles.OVMS W/dalvikvm﹕
>>> Am 15.01.2015 um 00:38 schrieb Michael Balzer:
>>>> Mark,
>>>> I managed to import the App code into Android Studio and build the
>>>> App, currently running successfully on Android 5.0.2 on my tablet
>>>> -- not yet tested on my 2.3 phone.
>>>> I have fixed the OCM integration and the USSD code entry, also
>>>> added a homelink reset menu option and extended the "D" message
>>>> parsing to include 12V reference and charging info, which is then
>>>> displayed on the car info sheet.
>>>> I'll fix the OCM range switch tomorrow (if I find the time).
>>>> I'd like to push my changes back into github, but it seems the
>>>> change to Android Studio / Gradle modified a lot of files, even
>>>> directory layout. It seems I'll have to create a new repository,
>>>> breaking the version history. I'll see if I can do something about
>>>> that and work in my own github account first.
>>>> Regards,
>>>> Michael
>>>> Am 13.01.2015 um 07:03 schrieb Mark Webb-Johnson:
>>>>> This seems to be a one-liner in res/layout/dlg_pin.xml:
>>>>> <EditText android:id="@+id/etxt_input_value"
>>>>> android:layout_width="match_parent"
>>>>> android:layout_height="wrap_content"
>>>>> android:digits="0123456789"
>>>>> android:password="true"
>>>>> android:inputType="numberSigned" />
>>>>> It seems that the re-use of the showPinDialog in so many places in
>>>>> the Android code is a bit restrictive.
>>>>> We could try changing this to andoid:inputType textPassword.
>>>>> Regards, Mark.
>>>>> On 12 Jan, 2015, at 1:57 am, Michael Balzer <dexter at expeedo.de
>>>>>> Hi Pierre,
>>>>>> that's a known bug of the App. You currently need to use the perl
>>>>>> client to send USSD codes.
>>>>>> Command code for this is 41, so for your USSD code it's...
>>>>>> ./cmd.pl 41 "*131#"
>>>>>> Regards,
>>>>>> Michael
>>>>>> Am 11.01.2015 um 17:33 schrieb Pierre Uhl:
>>>>>>> Hi everybody,
>>>>>>> I am trying to use USSD Codes. But the App (Android 3.2.2) does
>>>>>>> not accept * and # but only numbers. How can I input *131# to
>>>>>>> recharge the Prepaid SIM-Card?
>>>>>>> Pierre Uhl
>>>>>> Michael Balzer * Paradestr. 8 * D-42107 Wuppertal
>>>>>> Fon 0202 / 272 2201 * Handy 0176 / 206 989 26
>>>>>> <dexter.vcf>_______________________________________________
>>>>>> OvmsDev mailing list
>>>>>> OvmsDev at lists.teslaclub.hk <mailto:OvmsDev at lists.teslaclub.hk>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20150124/0dbb40ce/attachment.htm>
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20150124/0dbb40ce/attachment-0002.vcf>
