[Ovmsdev] Android update 3.2.3
Marcos Mezo mmezo at selexco.net
Sat Jan 24 20:34:00 HKT 2015
Would you consider adding the aplications to an alternative market? I
was thinking of f-droid since it is specially for open-source software.
I have a mostly google free phone without any account and would greatly
apreciate it.
Thank you,
Marcos
> Michael,
> I've added you to the maintainers list for the Android repository.
> On 17 Jan, 2015, at 10:38 pm, Michael Balzer <dexter at expeedo.de
> <mailto:dexter at expeedo.de>> wrote:
>> Hi again,
>> the directory structure changes are not that complex, it's just
>> another root directory and the sources subdirectory is named "java"
>> instead of "src".
>> So here are my changes so far:
>> https://github.com/dexterbg/Open-Vehicle-Android/commit/56445e31a3de48dfde97956ce70b1153f6729922
>>  Version 3.2.3:
>> - OCM API update: fixes missing stations, missing detail data
>>   and station address encoding issues
>> - USSD code dialog is now text field allowing "*" and "#",
>>   default "*100#" (account balance query in most networks)
>> - 12V battery state display (car info)
>> - Renault Twizy: "Homelink" gets "Profile" and extended by "Default"
>> Mark, you need to pull this or add me, I cannot push into the project
>> repository.
>> Haven't begun on the range switch, I'm stuck building for my Android
>> 2.3.5 phone -- everything works except the OCM markers, and the log
>> contains lots of resolver errors (see below). Tried different build
>> settings and also replacing the google-play-services.jar, but nothing
>> helps so far.
>> It must be some build config, as it runs perfectly on my 5.0.2
>> tablet. If anyone's got an idea on this, let me know.
>> Resolver errors on Android 2.3.5:
>> 01-17 13:31:56.788    7099-7099/com.openvehicles.OVMS W/dalvikvm﹕
>> VFY: unable to find class referenced in signature
>> (Landroid/app/Fragment;)
>> VFY: unable to resolve virtual method 90:
>> Landroid/app/Activity;.getFragmentManager ()Landroid/app/FragmentManager;
>> 01-17 13:31:56.948    7099-7099/com.openvehicles.OVMS W/dalvikvm﹕
>> VFY: unable to resolve virtual method 6780:
>> Lcom/actionbarsherlock/internal/nineoldandroids/widget/NineFrameLayout;.onHoverEvent
>> (Landroid/view/MotionEvent;)Z
>> 01-17 13:31:56.958    7099-7099/com.openvehicles.OVMS W/dalvikvm﹕
>> VFY: unable to resolve virtual method 5406:
>> Landroid/widget/FrameLayout;.getAlpha ()F
>> VFY: unable to resolve virtual method 5408:
>> Landroid/widget/FrameLayout;.getTranslationY ()F
>> VFY: unable to resolve virtual method 5412:
>> Landroid/widget/FrameLayout;.setAlpha (F)V
>> VFY: unable to resolve virtual method 5420:
>> Landroid/widget/FrameLayout;.setTranslationY (F)V
>> 01-17 13:31:56.968    7099-7099/com.openvehicles.OVMS W/dalvikvm﹕
>> VFY: unable to resolve virtual method 5100:
>> Landroid/view/ViewGroup;.getAlpha ()F
>> VFY: unable to resolve virtual method 5111:
>> Landroid/view/ViewGroup;.getTranslationX ()F
>> 01-17 13:31:56.978    7099-7099/com.openvehicles.OVMS W/dalvikvm﹕
>> VFY: unable to resolve virtual method 5112:
>> Landroid/view/ViewGroup;.getTranslationY ()F
>> VFY: unable to resolve virtual method 5134:
>> Landroid/view/ViewGroup;.setAlpha (F)V
>> VFY: unable to resolve virtual method 5139:
>> Landroid/view/ViewGroup;.setTranslationX (F)V
>> VFY: unable to resolve virtual method 5140:
>> Landroid/view/ViewGroup;.setTranslationY (F)V
>> 01-17 13:31:57.008    7099-7099/com.openvehicles.OVMS W/dalvikvm﹕
>> VFY: unable to resolve virtual method 7644:
>> Lcom/actionbarsherlock/internal/widget/ActionBarView$HomeView;.onHoverEvent
>> VFY: unable to resolve virtual method 5410:
>> Landroid/widget/FrameLayout;.onPopulateAccessibilityEvent
>> (Landroid/view/accessibility/AccessibilityEvent;)V
>> 01-17 13:31:57.049    7099-7099/com.openvehicles.OVMS W/dalvikvm﹕
>> VFY: unable to resolve virtual method 4995:
>> Landroid/view/View;.jumpDrawablesToCurrentState ()V
>> VFY: unable to resolve virtual method 5003:
>> Landroid/view/View;.onInitializeAccessibilityEvent
>> VFY: unable to resolve static method 5027:
>> Landroid/view/View;.resolveSizeAndState (III)I
>> 01-17 13:31:57.079    7099-7099/com.openvehicles.OVMS W/dalvikvm﹕
>> VFY: unable to resolve static method 7853:
>> Lcom/actionbarsherlock/internal/widget/IcsAbsSpinner;.resolveSizeAndState
>> (III)I
>> 01-17 13:31:57.089    7099-7099/com.openvehicles.OVMS W/dalvikvm﹕
>> VFY: unable to resolve virtual method 5117:
>> Landroid/view/ViewGroup;.onInitializeAccessibilityEvent
>> (Landroid/view/accessibility/AccessibilityNodeInfo;)
>> VFY: unable to resolve virtual method 5118:
>> Landroid/view/ViewGroup;.onInitializeAccessibilityNodeInfo
>> (Landroid/view/accessibility/AccessibilityNodeInfo;)V
>> VFY: unable to resolve virtual method 5122:
>> Landroid/view/ViewGroup;.onRequestSendAccessibilityEvent
>> (Landroid/view/View;Landroid/view/accessibility/AccessibilityEvent;)Z
>> 01-17 13:31:57.099    7099-7099/com.openvehicles.OVMS W/dalvikvm﹕
>> VFY: unable to resolve direct method 5551:
>> Landroid/widget/PopupWindow;.<init>
>> (Landroid/content/Context;Landroid/util/AttributeSet;II)V
>> 01-17 13:31:57.109    7099-7099/com.openvehicles.OVMS
>> E/ResourceType﹕ Style contains key with bad entry: 0x01000000
>> 01-17 13:31:57.109    7099-7099/com.openvehicles.OVMS W/dalvikvm﹕
>> VFY: unable to resolve virtual method 5473:
>> Landroid/widget/LinearLayout;.getAlpha ()F
>> VFY: unable to resolve virtual method 5476:
>> Landroid/widget/LinearLayout;.getTranslationX ()F
>> VFY: unable to resolve virtual method 5488:
>> Landroid/widget/LinearLayout;.setAlpha (F)V
>> VFY: unable to resolve virtual method 5498:
>> Landroid/widget/LinearLayout;.setTranslationX (F)V
>> 01-17 13:31:57.249    7099-7100/com.openvehicles.OVMS E/Database﹕
>> close() was never explicitly called on database
>> '/data/data/com.openvehicles.OVMS/databases/sampledatabase'
>> android.database.sqlite.DatabaseObjectNotClosedException: Application
>> did not close the cursor or database object that was opened here
>>             at
>> android.database.sqlite.SQLiteDatabase.<init>(SQLiteDatabase.java:1960)
>>             at
>> android.database.sqlite.SQLiteDatabase.openDatabase(SQLiteDatabase.java:906)
>>             at
>> android.database.sqlite.SQLiteDatabase.openOrCreateDatabase(SQLiteDatabase.java:940)
>>             at
>> android.database.sqlite.SQLiteDatabase.openOrCreateDatabase(SQLiteDatabase.java:933)
>>             at
>> android.app.ContextImpl.openOrCreateDatabase(ContextImpl.java:614)
>>             at
>> android.content.ContextWrapper.openOrCreateDatabase(ContextWrapper.java:203)
>>             at
>> android.database.sqlite.SQLiteOpenHelper.getWritableDatabase(SQLiteOpenHelper.java:118)
>>             at
>> com.openvehicles.OVMS.ui.utils.Database.get_ConnectionTypes_Main(Database.java:222)
>>             at
>> com.openvehicles.OVMS.utils.ConnectionList.<init>(ConnectionList.java:46)
>>             at
>> com.openvehicles.OVMS.ui.MainActivity.onCreate(MainActivity.java:59)
>>             at
>> android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1072)
>>             at
>> android.app.ActivityThread.performLaunchActivity(ActivityThread.java:1836)
>>             at
>> android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:1893)
>>             at
>> android.app.ActivityThread.access$1500(ActivityThread.java:135)
>>             at
>> android.app.ActivityThread$H.handleMessage(ActivityThread.java:1054)
>>             at android.os.Handler.dispatchMessage(Handler.java:99)
>>             at android.os.Looper.loop(Looper.java:150)
>>             at android.app.ActivityThread.main(ActivityThread.java:4385)
>>             at java.lang.reflect.Method.invokeNative(Native Method)
>>             at java.lang.reflect.Method.invoke(Method.java:507)
>>             at
>> com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:849)
>>             at
>> com.android.internal.os.ZygoteInit.main(ZygoteInit.java:607)
>>             at dalvik.system.NativeStart.main(Native Method)
>> 01-17 13:31:57.879    7099-7099/com.openvehicles.OVMS W/dalvikvm﹕
>> Am 15.01.2015 um 00:38 schrieb Michael Balzer:
>>> Mark,
>>> I managed to import the App code into Android Studio and build the
>>> App, currently running successfully on Android 5.0.2 on my tablet --
>>> not yet tested on my 2.3 phone.
>>> I have fixed the OCM integration and the USSD code entry, also added
>>> a homelink reset menu option and extended the "D" message parsing to
>>> include 12V reference and charging info, which is then displayed on
>>> the car info sheet.
>>> I'll fix the OCM range switch tomorrow (if I find the time).
>>> I'd like to push my changes back into github, but it seems the
>>> change to Android Studio / Gradle modified a lot of files, even
>>> directory layout. It seems I'll have to create a new repository,
>>> breaking the version history. I'll see if I can do something about
>>> that and work in my own github account first.
>>> Am 13.01.2015 um 07:03 schrieb Mark Webb-Johnson:
>>>> This seems to be a one-liner in res/layout/dlg_pin.xml:
>>>>             <EditText android:id="@+id/etxt_input_value"
>>>>     android:layout_width="match_parent"
>>>>     android:layout_height="wrap_content"
>>>>                     android:digits="0123456789"
>>>>                     android:password="true"
>>>>     android:inputType="numberSigned" />
>>>> It seems that the re-use of the showPinDialog in so many places in
>>>> the Android code is a bit restrictive.
>>>> We could try changing this to andoid:inputType textPassword.
>>>> Regards, Mark.
>>>> On 12 Jan, 2015, at 1:57 am, Michael Balzer <dexter at expeedo.de
>>>>> Hi Pierre,
>>>>> that's a known bug of the App. You currently need to use the perl
>>>>> client to send USSD codes.
>>>>> Command code for this is 41, so for your USSD code it's...
>>>>> ./cmd.pl 41 "*131#"
>>>>> Regards,
>>>>> Michael
>>>>> Am 11.01.2015 um 17:33 schrieb Pierre Uhl:
>>>>>> Hi everybody,
>>>>>> I am trying to use USSD Codes. But the App (Android 3.2.2) does
>>>>>> not accept * and # but only numbers. How can I input *131# to
>>>>>> recharge the Prepaid SIM-Card?
>>>>>> Pierre Uhl
>>>>> Michael Balzer * Paradestr. 8 * D-42107 Wuppertal
>>>>> Fon 0202 / 272 2201 * Handy 0176 / 206 989 26
>>>>> <dexter.vcf>_______________________________________________
>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20150124/9236aa64/attachment.htm>
